Question about Toshiba Satellite A105-S1013 Notebook
Can get pass the toshiba screen
When i turn on my laptop, it says, there an error. Resource Conflict _PC Network Cotroller on Motherboard
Bus : 02, Devise :04 Function : 00
Bus : 02, Devise :06 Function : 00
Bus : 02, Devise :07 Function : 00
what's wrong with my laptop.can pass the toshiba screen and when i press
f2 to set up and check all are normal and back to boot and above are the data
showing on the screen. PLEASE HELP.
  • 125 Answers
Go into the bios and then to exit there you will see load setup defaults a screen will pop up asking you yes or no choose yes then save changes and reboot
Posted on Jul 27, 2009
Resource conflict pci motherboard
Set your bios to default. It might fix the problem.
Jan 25, 2014 | Toshiba Satellite A85-S107 Notebook
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Toshiba Satellite A105-S1013 Notebook Logo
207 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
