Hello
first you have to check if the it is software problem try to tr install the software first and if the message is still showing try to unplug the power from the wall outlet also at the back of the scanner after 5 minutes plug it again. if the message is still showing then is problem with the lamp of the scanner it is mechanical problem.
thank you
SOURCE: office jet g85
Power on the printer, wait around 15 seconds until
the bulb assembly moves a bit to the left and the light goes on, then
immediately power off.
Repeat the process around 15 times (or
more) until the assembly has moved all the way to the left of the
glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using
a dry Q-tip, carefully insert it into the slot (to the left of the
bulb) and clean the mirror. I found mine was coated with a layer of
film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
SOURCE: Scanner Failure
this is very common problem many users of this type of printer are getting the same problem.final solution for this problem is change the scanner unit.it will cost you between 50$ to 60$ exact. rate this solution as fixya and give respect to our technical experince that saved your precious time.thank u for using fixya.
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
cloth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Does it work sometimes, my PSC 750 from 1999 still scans but sometimes says that
