Question about Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine Model 110.20862990
Machine stops working at rinse cycle - the machines stays full of water and will not drain. Have checked outlet hose and that is clear. How do I open the rear panel?
Thanks
  • asimali2002 Aug 07, 2008
    My Kenmore washer is fillin up with water, timer is also working(i see it moving all the way to off), and I do hear the clickin switch when I shut/unshut the door.
    Problem started yesterday when my wife put a heavy load including some blankets, it didnt run, then I pulled everything out and drained all the water manually. And gave it a 2nd shot with less clothes, water was filled, but its not spinning/moving at all. Not sure what the problem can be? any assistance is greatly appreciated
    Thanks in advance.
  • 5,911 Answers
You don't open the rear panel. This is a typical symptom of a lid switch problem. The link below will explain how to access it. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238). For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope this helps you. If you have questions, please let me know.
Posted on Aug 07, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
My machine stops working after the rinse cycle and won't go into the spin cycle. The water stays in the tub and will not drain. I have unplugged and replugged the machine just to make sure. I wanted to see...
It sounds like the Drain pump may have stopped working. After the rinse cycle, the machine should drain the water and start spinning. The Drain Pump should be at the bottom of the machine.
Feb 22, 2011 | Roper RAS6233KQ Top Load Washer
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kenmore 24032\24036 Top Load Washer Logo
336 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
