Question about Dell Inspiron 1501 Notebook
Usb drivers? i think
I know almost nothing about computers. but when I plug in my jump drive my computer trys to install the correct drive and it never works. this jump drive works on other computers. anything i plug in to the usb does not work. can you help me? OS vista
    Genius:
  • 2,028 Answers
Two things to check, 1- make sure the usb drivers are intalled and the usb ports are enabled and working properly in the device manager, and 2- go into the bios or set up at start up and see if there is an option to enable or disable the usb ports. If so, make sure that they are enabled. Let me know what type of jump drive are you trying to use, make, model,etc..? It could be the drive.
Posted on Jul 31, 2008
Drive not recognized and driver wont install
Check all your cables are attached correct and well.
The drive should hum/buzz/vibrate gently if no sound there maybe no power getting to it. If there is sound/vibrating coming from to drive check the USB is connected correctly...
If it is, disconnect the drive by the USB and update your drives and make sure you have the most up to date MS service pack.
Restart your computer to ensure all updates are installed.
Reconnect the USB lead from the drive (make sure the drive's power is on)
windows Should now automatically install the driver. (This may take a minute to start)
If worst come to pass and nothing works you can try rehousing the drive or connecting it directly to computer.
Jan 27, 2014 | Fantom Drives GF2000EU 2 TB USB 2.0 Hard...
How do you put this into your computer does it pop up
First you plug it into a a USB port (you'll know what I mean since they're the only slots that will accept that device). Then it MAY pop up, but if it does not it will show up in My Computer, or in "Computer" depending on your operating system.
Go to Start then select My Computer, or go to the Start Orb and go to Computer if you're using Vista or Win 7.
Now that you're in My Computer or Computer, you will see a list of all of your drives. Your USB Drive is one of these (assuming your USB Drive is operating correctly).
Typically the drive that holds your operating system is drive C:\. Your CD/DVD ROM drive is drive D:\. and all drives added after that will be given the next letter in the alphabet, so your USB drive will probably be drive E:\.
Now if your USB drive is plugged in correctly, but it is not showing up in My Computer or Computer then you should probably download the latest Universal Serial Bus drivers for your motherboard.
First download and use a program such as SandraLite
http://www.filehippo.com/download_sandra_lite/
This is a hardware diagnostic utility. Install and run it and then under the Mainboard section your will find the model number and manufacturer of your motherboard. With that information you can go to their website and should be able to download the latest Universal Serial Bus drivers for your motherboard.
Hope this helps. If it does not, please comment back and let us know!
Dec 25, 2010 | Dane-Elec DaneElec 1GB USB Drive Red 1 GB...
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
Mouse jumps around hard to control
If this is an older wireless mouse setup with two connections to the computer one ps2(round plug) and another usb(flat plug) try restarting the computer with the usb moved to another port. Make sure the ps2 plug is securely plugged in to the correct ps2 port.
Mar 05, 2010 | Logitech Cordless Mouse
I can't use printer from computer,all it's saying on the instructions I got was, plug power in and ubs cord to printer,nothing hooked into my tower, go figure???? so how do I do it,it's a new computer,just...
Plug the USB cord from the printer to an available USB connector on your tower, insert printer disk into computer drive, then go through Printer Setup and you should be able to print.
Dec 14, 2009 | HP Ruggedized DC Car Adapter for HP...
Need to plug in a data cable. need usb software installation?
Plug in the USB device, anyways.
If it works, the driver has already been installed.
If not, take the USB device back to the retail store where you bought it, and get them to demonstrate how to correctly configure and install the device, using one of their computers.
Nov 09, 2009 | Computers & Internet
Data transferring trouble
I think first you want to use the correct data cable for your phone. then you have to install the drivers for your phone in to your computer. Then only you can transfer files between computer and phone. You can download the drivers from the internet.
Jul 27, 2009 | LG Shine KE970 Cellular Phone
I have a square lookin delstar mp3 and i don't know how to put songs in it.......culd u tell me how....pleze???? i want to get the music from youtube..oh yeah..it has 4GB!!! I LOST THE CD DRIVER SO I CAN...
if you have a windows machine, first plug the mp3 player in to one of the empty usb ports on your computer and let windows install it, now use windows media player to songs to it using sync or copy music to device
Jun 23, 2009 | Delstar DS 31024 MP3 Player
Usb 2.0
i think oyur drive had problem change your drive and try it.
Mar 23, 2008 | EPoX (EP-4SGM8I) Motherboard
Dell Inspiron 1501 Notebook Logo
71 people viewed this question
Alun Cox
