Cannot adjust convergence on the blue. Its curved upward in the middle.Also showing a second image in blue. have manaully tried to adjust blue convergence over the cross hair, able to moves side to side but not up or down. Red is fine one shop to me if that was the problem it would cost $600.00 to the tv is only 4 years old
  • 1 more comment
  • tatonetti Aug 02, 2008
    model is 46PP8621 purch 29/02/2004 PHILIPS thanks.
  • tatonetti Aug 04, 2008
    model 46PP8621 philips 2004
  • fifthdemn May 08, 2009
    I have the same problem with my 60" Philips Magnavox Flat screen (9P6040C102) My blue will not line up from left and right. Also, the color seems very bright. Is this the same problem? If so, please give some help.
    Charlie
  • 8,617 Answers
Whats the model number and i will post the ICs you need and post a link where you can get them with free step by step instructions with pictures so you can do the repair yourself and the ICs arent exspensive. Please reply to this same post.
Posted on Jul 31, 2008
  • Sonny Berry
    Sonny Berry Aug 04, 2008
    Your model uses two STK392-120 Convergence ICs and you will also need about four 6.8 ohm 1watt resistor. The following link has the ICs and resistors and they will provide free insatalation instructions with pictures and free online tech support when you do the repair in case you have any questions during the repair.
    Heres the link.
    http://servicemanuals.vstore.ca/
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Rca 61in. tv is showing a curved picture. when the cable is off it shows a red, green, and blue curved line across the screen.
Hello! This is eagle.. What happened.. You didn't type a single word! You tried twice and I picked up the chat both the times..Looks like some kind of connection problem.. I have been waiting forever for you to type! Anyways can you please post an image of the set powered on? Also did you try adjusting the convergence settings of the set?
Nov 23, 2008 | Televison & Video
DOBLE IMAGE
THE CONVERGENCE DRIVER CHIPS NEED REPLACED. CHECKSUPPLY SAFETY RES ARE OK AFTER REPLACEING STKs RESET CONVERGENCE. CHANCE BOTH STKs.
Sep 09, 2008 | Toshiba 43H72 43" Rear Projection...
Youre convergence ICs need to be replaced. What is the model number of your set and I will be able to help you out with the problem
May 11, 2008 | Televison & Video
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
