Question about Whirlpool GH7155XHS Microwave Oven
Whirlpool YMH1170XS This microwave was purchase in Dec. of 2006. Just recently it stopped working. When I push the "30 sec" button or any other time amount, it turns on, makes a funny noise and then shuts off. I've noticed that our lights in the kitchen flicker when this happens. The fan still works as well as the light over the stove. Any ideas?
  • mimilley Aug 04, 2008
    We've been using it how it is for over a year now with no problems. Would having it not on its own breaker start to cause a problem at this point? When I enter in a time, it shuts off after 2 seconds everytime. I've also noticed that when I open the door, the light inside doesn't come on. I think It would be more like somebody hitting the stop button as the outside light and fan still work.
  • William Miller
    William Miller May 11, 2010
    Sounds like the microwave may not be on its own breaker. It should be.
    When it "shuts off", does it seems like someone hit the Stop button or like someone unplugged it?
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Maytag microwave OVER the stove
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: MIcrowave oven stopped heating - Whirlpool MH6150XMS
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Posted on Mar 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave No longer Heating Food
The most common cause of that is a shorted or blown high voltage rectifier diode.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
More info here: http://www.gallawa.com/microtech/diode.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Jul 04, 2008
localwonder
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Child lock on
This feature detects when your child pushes various buttons.
To reset/remove this message, disconnect the microwave from the mains power, wait for 30 secs and connect it to the mains power then set the Time and your microwave is ready for use.
Jan 22, 2012 | Panasonic Microwave Ovens
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
GE dvantium microwave stopped heating cookies on the 30 sec cycle
I have arranged for a GE technician to visit my home this Thursday.
Thanks for the e-mail
Sep 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Purchased an over the counter microwave oven, model JVM1540 DM2WW. It only seems to have 30 seconds as a minimum setting How can set the time at 10 sec. or less? (short of chosing "add 30 sec" and...
Went to the store where I bought it, and talked with a sales rep. in the appliance dept.
After paying $ 198 for the microwave and...$ 159 to have it installed, I was not about giving $ 9.99 more to answer a simple question.
Apr 04, 2008 | GE Microwave Ovens
Whirlpool GH7155XHS Microwave Oven Logo
137 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
