Question about Acer Aspire 5500 5570-2609 Laptop
Acer TravelMate 4200 Laptop
Laptop will not boot up. Black screen with the following:
PXE-M0F: Exiting Broadcom PXE ROM
Operationg System not found I just purchased a used Acer laptop online from ubid and it was supposed to come with Windows Vista. It came with a disk that says backup but I get the operating system not found error when i turn on the laptop. I changed the boot priority order in BIOS to every combination possible but i continue to get the operating system not found error? Any suggestions?
  • 102 Answers
Get solution from article on Black Screen of Death
Posted on Mar 07, 2014
    Sergeant:
    Champion:
  • 244 Answers
There are two posibility,
your hdd don't have operating system
or your hdd isnot detected.
check in bios, check if your hdd is there.
Posted on Aug 01, 2008
Broadcom base code PXE-2.1 v1.1.0 Operating system not found
Go to your laptop's bios and select first boot device as your hard drive. and also disable the other boot devices and boot from network must be disabled. that's all.
Sep 22, 2012 | Acer Aspire 5536-5224 Notebook
Problem with acer laptop. My laptop stopped booting after restart. I just moved my laptop from bed to floor . while in power on the program just crash not responding, then came a blue screen and said...
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. It looks like it is set to boot from a Network or LAN first. You want to boot from the hard drive 1st or the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Acer Computers & Internet
I have an Acer Aspire 5630 when i turn it on i get a black screen showing. PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM. Operating System not found I have got a...
The message is the laptops way of saying that it has looked for an operating system and could not find one. The PXE rom message refers to it trying to find a network boot record.
Test this by checking your Bios settings, in the boot order, see that the CDRom is set to 1st boot, then the second bot is the HDD, If the thing will not boot. Check you can see that the laptop "sees" the boot devices, if it does not, you have a problem, as it looks like the controllers are damaged.
If it Does find the boot devices, but it still defaults to a network boot, there is either NO OS on the hard drive, or it has been corrupted.
Use the Vista DVD to re-install Windows (you may be lucky enough to get away with a repair installation), after you have reinstalled windows, the drivers etc can be found on Acer's site quite easily
Jun 19, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Hi , my laptop seems to have crashed , it won't load up I have a black screen with the following writing Broadcom base code pxe-2.1 v1.1.0 Pxe-e61: media test failure , check cable Pxe- m0f : exiting...
Just follow these simple steps below and it should resolve the issue.
  1. When the computer is booting, go in the BIOS.
  2. Change the boot device priority so that your HDD becomes the first boot device.
  3. Disable network PXE boot if possible. If not possible, just put it as the last boot device.
  4. Press F10 to save settings and restart the computer.
  5. If problem is not solved at this stage, turn off the computer.
  6. Remove the lid and remove the HDD, clean the pins and reseat it.
  7. If issue persists, give a tap on the laptop where the HDD is located (I assure this works and has solved many problems) as there seems to be a 'strike zone' on some HDD.
Now turn on your computer and it should be running correctly.
Hope this helps you.
May 17, 2011 | Acer Aspire 5536-5224 Notebook
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Boot error PXE-E61: media test failure, check cable followed by, PXE-M0F: existing Broadcom PXE ROM followed by, Operating System not found
Hard drive has been coruppted. Hold alt f10 on statup to format and reinstall. If that dont work you may need to try install from cd's provided when you purchased laptop. If that dont work buy new hard drive and restore from cd's. Good Luck.
Nov 23, 2009 | Acer TravelMate 800LCi Notebook
Keep getting the following message when I turn on my Acer Aspire 5050 laptop: PXE-E61: Media test faulire, check cable PXE-M0F: Exiting PXE ROM Operating System not found
PXE bootup means the computer does not boot up from an operating system installed on a hard disk drive. PXE bootup uses a server on a network to boot up the computer.
It will not start without being connected the network that it was programmed to run on
Nov 16, 2009 | Acer Aspire 5050-3242 Notebook
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
This error is telling you there is nothing for the laptop to boot from.
The PXE meanes the laptop is trying to boot from the network adapter. If there is a hard drive in the laptop, then remove it and reinsert it again.
It could have suffered a catastrophic hard drive failure, or it could be just having an issue.
Also try putting a bootable cd/dvd into the drive and see if it will boot at least from that. If it does and you have access to another PC (you obviously do) and a cd burner, then search the net for "Hirens Boot Disc" download it and burn it.
This is a bootable cd that has a lot of tools for diagnostics of hard drives and a myriad of other things as well.
Apr 13, 2008 | Acer TravelMate 4200 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
349 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
