Question about Fowler Outside Micrometer Set 0 - 4"
Micrometer trouble I have a 2" to 3" outside micrometer. The lock ring was overtightened and now the barrell will not turn as smoothly. Can I fix this myself?
Have you looked at the granite surface plates? I think that it would work really well in this situation. I think that they are sturdy enough that they could get you the stability that you need.
Posted on Jan 18, 2012
My experience in this type of repair spans over 18 years of Calibration experience in working for a Major Automotive Supplier.
So I will attemp to walk you through this. There are several different models of micrometers and each manufacture has a different design. Most of my expertise is with Mitutoyo, Bown&Sharp and Starrett. There could be a couple of other under lying problems due to the "overtightening".
One: could be due to a scratch on the spindle "barrell" from trying to rotate the spindle when it was locked.
Two: the spindle could actually be bent.
Three: If left in the lock position for a period of time, it could have a slight bit of corrosion on the spindle.
If at all possible, remove the lock, loosen the spindle and remove the spindle completely. Place the spindle on a known flat surface. If you have a granite surface plate that would be perfect, if not try a smooth glass top. The idea is to check the spindle to see if it is bent by rolling it and checking for straightness. If it is bent or badly scratched, then it would be cheaper to just purchase a good micrometer from eBay than to try and get parts.
If it is not bent then it could be corrosion so clean with a pure grade alcohol and reassemble.
If you still have the tightness, then it could also be an alignment issue and that is just going to take a lot of patience, and it still may be cheaper in the long run to replace it.
Most precision mics will not tolerate harsh treatment or environments, so be careful..........hope this helps....
Posted on Dec 11, 2008
I have a fowler IP54 outside caliper micrometer 7-8" that is zeroed out. There are only 2 keys, a mm/in and zero. How do I reset to have it read 7.0 at 7.0?
Generally, micrometers are "zeroed" to a standard -- an object of a known specific length or diameter. If you have placed a 7-inch standard in the micrometer and brought the spindle into proper contact with that standard, and then zeroed the micrometer at that point, it will be properly set to seven inches. Standard micrometer travel is only one inch, and only that range is usually displayed. The user must then add the standard length to the face display or thimble reading to get the "developed" measurement.
Jan 08, 2015 | Fowler Measuring Tools & Sensors
How do i calibrate my speedygreen 2000 broadcast spreader
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
I lost my owner's manual and need to know how to reset the micrometer to zero
This is based on an old Brown & Sharp guide book. 1. Carefully clean the measuring surface by pulling a piece of soft paper between the surfaces while the anvil and spindle are in light contact with it. 2. with the anvil and spindle apart, unlock cap with spanner wrench (supplied with unit), then tighten cap lightly with fingers to bring slight tension between thimble and spindle. 3. Bring anvil and spindle together by turning SPINDLE and set zero line on thimble to coincide with line on barrel. 4. Move spindle away from anvil by turning SPINDLE, NOT by turning thimble. 5. Holding thimble only, tighten cap with fingers. Do Not Touch Frame. Lock cap with wrench, still holding thimble only, and adjustment is complete. NOTE: Check zero setting after adjustment is made. Hope this helps
Jun 04, 2010 | Mitutoyo #117 107 0 1 Uni Mike Micrometer...
Need to fix a leaking delta shower faucet and need to know how to take it apart. Single handle. only turns to left for on and farther left the hotter it gets,
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Mar 31, 2010 | Delta & Single Handle Shower Faucet
The locking nut on my micrometer does not lock anymore, can i fix this?
yes. Just remove the screw in the lock, lift the lock arm off its shaft, and reposition at different angle. (put to lock, take off without turning, and set back on at unlocked position...may ned adjusting)
good luck
Mar 28, 2010 | Mitutoyo 0 1".001 Fric/Thimble Mti Outside...
My model 449 starrett depth mic turns hard, how can I fix this?
Are you aware of the lock nut that keeps the barrel from turning? There is a knurled ring next to the base that rotates to lock and unlock the barrel with a clamping action. Check that this is not causing the problem. Turn to left to unclamp.
Oct 15, 2009 | Starrett 50443 12 Machinists' Improved...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
85CC TM RACING PISTON RINGS NEED HELP AS KEEP DO IN SAME THING
hi buddy you obviosly havent put it back together propally restrip it down and check for the following 2 circlips in either side of the piston where the wrist pin is also check the barrel is smooth by rubbing your nail in around the barrel if it feels rough or pumps get some glass paper and rub it around the barrel but dont keep rubbing one side as you will make the barrel oval shaped do it all evenly until its smooth then put the piston rings in the little pin slots on the piston then get some 2 stroke and rub around the barrel also make sure nothing has dropped down inside the crank shaft if so this will jam it up then put the barrel back on
Aug 27, 2009 | 2006 TM Racing MX 125
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Lock barrel switch
VI/WT = 50 RD/BK = 15 RD/YL = 15x RD/GN = 15r GN/WT = P or P30 Red = 30 Red = 30
Sep 17, 2008 | 1987 Mercedes-Benz Mercedes Benz 190 Class
Fowler Outside Micrometer Set 0 - 4" Logo
317 people viewed this question
Top Fowler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Fowler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
