Question about Jenn-Air Kitchen Ranges
When I try to light my jenn air gas cook top it clicks but will not light. But it will light with a match
I finally figured it out! The back burner would not light, the front burner would? In close inspection I found that there are two small holes at the base of the burner, facing the igniter tube. The back burner holes were clogged. I little scraping, and pushing with a toothpick cleared the holes, allowing gas to flow down the igniter tube and voila! The back burner lights!!
Posted on Oct 08, 2011
    Sniper:
  • 68 Answers
Your electronic ignitor is bad. You can buy a replacement ignitor where you bought your grill. Just about any hardware store will have a replacement ignitor. They are real easy to replace. There is 1 wire to the back of the ignitor. There is a retaining nut on the switch. Remove the switch and replace with new switch. Plug wire into ignitor, Turn gas on and test ignitor.
Happy Grilling
Please rate this solution
Posted on Jul 31, 2008
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn Aire gas cooktop
sounds like your initor button is stuck. If you are able to remove it, take a look and see if you can adjust it. If not, it will have to be replaced. Good luck.
Jul 14, 2010 | Jenn-Air JGA8100AD Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Nov 30, 2008 | Cooktops
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
313 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
