Question about Car Audio & Video
Put second motor in car,now i need security code for 1991 ford laser
  • 1,586 Answers
Take photo ID, title for the car, and registration to the dealership. This proves you are who you say you are, and that you own the car. They can use the documents to get the VIN number, and use the VIN to look up the code. This is the only way to do it, and any Ford dealer can do it. They may hit you for up to an hour's labor though, so be prepared.
Posted on Jul 31, 2008
Can I put a 1981 ford f-150 motor in a 1991 ford f-150 truck
Sounds to me like you opened a can of worms that you are not equipped/qualified to deal with. To begin with, doing an engine change the way you did it is illegal. It is OK to put the newer motor in the older vehicle, but it is against federal law to put the older engine into the newer vehicle. REFERENCE: EPA ENGINE SWAP FACT SHEET
With all that said, if you want to do a swap like that, it is necessary to also swap wiring harnesses and computer modules (among several other components) if you expect it to work.
Mar 17, 2012 | 1991 Ford F150
After battery recconected in 1991 ford laser how do i enter code to restart radio
The instructions are usually these
Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept.(sometimes it`s the [ 6 ] key to accept
The set should now operate.
Mar 10, 2011 | Car Audio & Video
Have got a 1990 ford laser and battery has gone flat, need to put the code in, have the code but cant figure out how to put it in??
Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept.(sometimes this is preset [ 6 ] )
Feb 28, 2011 | Car Audio & Video
Battery flat and have no security code for car radio. ford laser hatch KH 1991.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the SERIAL NUMBER found on a label on the etal casing
Aug 21, 2010 | Car Audio & Video
Trany problems
either ur torque converter isnt geting fluid or one of the valve bodys in blocked and not gettin fluid through thats what im thinking, or could be ur linkage needs adjustin ya . derrick
Dec 08, 2009 | 1991 Ford F150
I have switched my motor to carberated and put a different automatic transmission in also and the trany will not shift. i put it in overdrive and it stays in first gear and if you shift it manually into...
The transmission should have a vacuum line going to it. It needs this vacuum to shift into the next gear. Try locating it and connect a vacuum line from the carb to the trans.
1991 ford probe
duck tape on the air intake. I just fixed mine. There is a crack on the intake that lets too much air in when you put it in drive that makes the car stall. Try it it works.
Nov 23, 2008 | 1990 Ford Probe
Stereo security cide needed.
Look, what is the serial number? what is the car model? search it in google and you'll find, type: "answer (your car model or serial number) radio code" in the search adress
Jun 23, 2008 | 2006 Ford Laser
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
