Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell 1697w Powersteamer
I have the Bissel 1697w from Walmart. It has been used a few times, but now the water solution does not spray. I turn it on and the brushes turn, but when I pull the trigger, no water. I took it apart but failed to see anything that looked wrong. Any ideas? I have the Bissell Proheat 2X. Same problem. water doesn't spray. I thought I had cleaned it when I put it away but after being stored it doesn't work.Does one have to take all the hoses,etc. apart and clean them after use?
  • Anonymous Feb 04, 2009
    I had the same problem, Bissell Customer support told me it is out of warrantee. I used it once, put it away in garage after cleaning it real good. took it out and would not spray water again.
Http://www.bissell.com/images/UserGuides/1697_207.pdf
go to bissell.com on the right hand side is the link were you type in your model number. it will take you to it you click more info and it opens a page to access the user guide. i had the same problem and after looking at the user guide found i had a broken belt (near the flow indicator there is a section that can open use a flat head screwdriver to pry it open and you can see the belt) i dont know if that will work yet b/c i just found it so im on the way to get a new belt. hope this helps
Posted on Sep 10, 2008
2 Suggested Answers
SOURCE: Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Posted on Dec 22, 2006
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
I purchased my Bissel PowerSteamer Clearview a few years or so ago, and cannot find where I filed the manuals. If I find the actual seriel number on the Bissel PowerSteamer Clearview, Is there a way that I...
No need my friend. Go here. All documentation is here...and....it's free! Hope this helps : )
http://www.bissell.com/user-guides/?searchtext=1699%2520pro%2520heat&searchType=search&mode=228
Jan 07, 2011 | Bissell 1699 ProHeat Clear View Upright...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have had my Bissel Powersteamer Pro (green) for a few years, but have never used it. I can't find my manual and I have no idea how to use it. Help!!
fill reservoir with water and solution. Then you can push release trigger and vacuum . Don't over fill and do not let stay in one place too long as it will soak area. It takes a feel to get used to.
Mar 07, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel 1695 - pump not turning on. Vacuum turns on
bad switch or connecter at switch or the pump is plugged
Feb 22, 2009 | Bissell 1695 PowerSteamer Vacuum
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
334 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
