SOURCE: my vulcan double oven is
if the unit is tripping fuses then there is either an active or neutral fault in most cases the fault is a ground fault cased by a burned out heating element check the elements for cracks and burn marks if you find one replace the element
best of luck to you
p.s regardles of the fault in this case its not expensive to repair its a common and east fault to have repaired
No fix, just a comment- Convection ovens in general are very good at producing crisp results on roasts and similar but for cakes?
Thanks for the comment. I have used other convection ovens and have not had this problem. Has anyone else ever experienced this?
you may want to try cooking on different level shelves.
