Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
The green light for "clean" is blinking green and
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Mar 07, 2011
  • richard rosen Jan 05, 2013
    worked..thought I was going to have to get a new machine !!! thanks..
  • xjock8098
    xjock8098 Mar 26, 2013
    Nicely done! Don't have a manual; the DW came with the house. Freaked out; totally feel better now! Thanks, Kevin!
SOURCE:
Green light is blinking --says clean when you push
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
Blinking Green Light
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
My dishwasher blinks the green clean light
May have a bad heater. press hi temp, air dry,hi temp, air dry (or whatever button is equivalent on your model). this starts a test and will allow unit to work again. When drying light goes out touch the heater. If it is cold then it may be bad. You will need a voltmeter to tell for sure however.
May 27, 2010 | Whirlpool 24 in. GU2548XTP Built-in...
Green light flashing, won't turn on
A blinking light, and possibly no lights, with the door closed may indicate faulty door switches (very common on newer models). Depending on the model, the switches can be removed, cleaned and put back
Jun 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
"Clean light" keeps blinking; dishwasher won't start new cycle
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Feb 07, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
914 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
