Question about Olympus Camedia D-390 Digital Camera
D-390 Got new 2GB card...won't format...says 'card error'. Card too big for camera? Or am I doing something wrong?
  • caladu2 Aug 20, 2008
    I have the same problem i bought a 1gb card and it won't format. Any ideas?
  • jsatmariet Dec 04, 2008
    Won't let me format. New 2GB card and AA batteries. Whats up?
    President:
  • 919 Answers
The problem is that the largest xD card that your camera can support is a 256mb card without the M or H letters on it. The 1gb or 2gb card is not compatible.
Posted on Dec 17, 2008
I bought a new memory card for my Canon Power Shot SD 400 Digital Elph, but it has an error message that comes up. When I scrolled through the Menu to format the card, the format selection is grey and...
Your older camera can only work with 2GB or smaller standard SD cards. It is not capable of recognizing the newer format 4GB or higher SDHC cards. Fortunately, old format 2GB SD cards are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them.
Sep 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
My c703 won't format a new memory card. The old memory card is full (2GB), but I've tried two NEW Lexar 4GB cards and neither will format. Help!
Hi, The reason neither 4GB card will format is because that camera is only able to support, at most, a 2GB card. I'd suggest returning the 4GB card and getting another 2GB one.
May 13, 2011 | Kodak EasyShare C703 Digital Camera
Please describe your why do i get an error when i try using the sd card in my gatewayDCT20 camera
Usually when you see errors with the card it will be due to a few things. The card is bad or corrupt, the card is the wrong type, or the camera has a fault.
Usually the problem is the card (9 out of 10 times). The cards may need to be formated before use or if they go bad to correct them. If the camera won;t give you the option then try doing this on a laptop or using a card reader and try again. Usually card errors are from bad shut downs or running out of power while taking pictures. Sometimes the card is is dead and won't be fixed by reformatting so you can only replace it. (Don;t toss it as it might work in a laptop).
If the card is too big or the wrong speed some cameras will give an error. Not much you can do about this other than getting a new card. Nothing wrong with the card its just not compatible.
If you have this problem with several cards then the camera itself may be at fault. Unfortunetly that usually means repairing the camera or replacing it. Replacement is usually cheaper.
Jan 20, 2011 | Cameras
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
Jan 04, 2010 | Jazz DV152 Camcorder
Format problems
Hi: Did you unlock the XD?
If the Xd is not unlocked, then you can not access it and format it.
Your Xd might be too big for your camera.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cyber Master
Jun 28, 2009 | Cameras
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
How to format new xD card for Olympus D-390 when I press OK to Format- I get blue Card Error!
The problem is that the largest xD card that your camera can support is a 256mb card without the letter M or H in front of the 256. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support storage that large. The cards came out long after the camera did.
Feb 19, 2009 | Olympus Camedia C-310 Zoom Digital Camera
Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
Hey,
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Pentax Optio 30 Digital Camera
I just got a brand new Olympus xD Picture Card (M 2GB) for my Olympus D-390 Camedia Digital Camera. When I turn it on, the 'Card Setup" screen comes up. When I try to format the card, I inevitably...
The problem is that the largest xD card that your camera can support is a 256mb card without the letters M or H on it. The 1gb and 2gb cards are not compatible.
Aug 25, 2008 | Olympus Cameras
New memory card
did you formate it in the camera or your pc? formate in the camera first and is there a lock switch on the card?
Jan 01, 2008 | Olympus Camedia D-390 Digital Camera
Olympus Camedia D-390 Digital Camera Logo
158 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
