Question about GE Kitchen Ranges
Gas oven's broiler works. Regular oven does not.
    Sniper:
  • 68 Answers
There could be several reasons.
  1. You could have 1 bad element.
  2. You could have a loose connection in the stove. Try removing the element and reinstalling to reset the element.
  3. Your selector switch could be bad. Contact an electrician for electrical checks
Please rate this solution
Posted on Jul 31, 2008
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
SOURCE: GE gas oven won't heat
Replaced glow plug its getting current but still not glowing. Tested resistance 1100 showed good,
but glow plug still no lighting
Posted on Dec 13, 2008
jsrock516
  • 5911 Answers
SOURCE: oven gas in intermitit. broiler works but oven gas
This problem is commonly attributed to a bad igniter on the bake manifold. Each oven manifold (one for bake, one for broil) has its own igniter. They are both fed from the same gas source, though. So, if the broiler works, more than likely you simply need to replace the bake igniter. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter tends to wear out faster, due to the frequency of use.
You can purchase replacements on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just use you model number as your search criteria.
This is a simple repair that anyone can do on their without the need of a service call. Just follow the steps provided. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 30, 2009
  • 89 Answers
SOURCE: GE gas range model JGBS10BEH2BB oven and broiler
you need to check the ignitor even if the ignitor glows it might not be pulling enough amps to call for gas replace the ignitor and this should take care of the problem
Posted on Aug 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore oven model#362.7122891 gas oven and broiler wont work
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
BROILER HAS NO REGULAR IGNITION DESPITE THE FACT THAT THE VALVE AND IGNITER ARE FINE AND BROILER AND ORIFICE IS IS CLEAN. GAS PRESSURE AND FLOW IS FINE. ONCE LIT (MANUALLY WITH A LIGHTER) THE FLAME W
How do you know the ignitor is fine? The ignitor for the oven is different than that of the burners. Rather than clicking, the oven ignitor will glow red. If when you turn of the oven you don't see a source of red light coming from under the oven bottom your ignitor is bed.
Aug 30, 2014 | Kitchen Ranges
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
How to relight the pilot light?
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
Sep 19, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Gas broiler works, but the regular oven works intermittently, can you explain how this can happen.
The ignitor for the oven could be going bad and causing the oven valve to open intermittently. I see this often. Or the oven valve could be going bad... but the usual suspect is the ignitor.
Tom
Aug 10, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
The problem is our over which I think is a GE JGRP17 Gas Single Oven based on descriptions on this site, the stove burners and broiler are working but the regular oven won't work, the igniter doesn't glow...
the problenm is in the ignitor. there is a possibly a break in the ignitor to where there is no continuity in. I would buy a new ignitor and then shut off the gas to the oven and replace the ignitor. That will solve your problem. Have a Merry Christmas and thank you for using FixyA!!
Dec 25, 2008 | GE JGRP17 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
