Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Parts main circut board
Hello Mr. BerryI have a 50gx30b Hitachi, I have contrast control, the contrast is black, andtheir is no change when I try to ajust it. What board can I change to fix it?A ware can I get the baord.Rick J.Text me at 404 719 3676
Posted on Aug 15, 2012
  • Hitachi Master
  • 8,617 Answers
Which board are you refering to as the main circuit board? The power supply PWB ? The Deflection / Convergence PWB ? or the Signal PWB ? respond to this same post and I can help you out, but there isnt a PWB called " main" In that chassis hitachi.
Posted on Jul 31, 2008
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
May 08, 2012 | Samsung Microwave Ovens
Tv clicks on and goes right off. I pushed menu and input buttons and got 2 fasshs folloed by 4 flasshs. Its a 2000 mitsubishi tv. What is the problem?
Hello
The problem si with some short circuited component/s in its main power supply regulator board. Check the horizontal output transistor on the main board also for short circuted to collector to emitter.
Mar 04, 2012 | Mitsubishi VL-2000 TV
Nova has a interm furnace and needs a circut board
Go to hvac parts,com and have your model and serial number ready. They will have it cross it to another one that will work .Rus
Nov 28, 2009 | Heating & Cooling
Bosch SHX46A05UC/30 runs for 4 hours.
The circut board in the biege plastic case under the buttons on the right has what is called a cold solder. In other words the solder melts under operational use. Some are repairable and some are not.
1. UNPLUG DISHWASHER or turn off breaker and test for electricity.
2. Remove screws from door panel.
3. Take pic of position of wires going into plastic box.
4. Remove top section of plastic box with buttons exposing small circut board.
5. Open plastic box exposing large circut board and in the middle of it you will see a black spot where the solder has popped. Resolder and reassemble OR replace old circut board and then reassemble.
A new circut board is about $135
Usually electrical parts are not returnable
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-1.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-2.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-3.jpg
Oct 23, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Replace the electrical circut board in cuisinart ccm 16pc grinder
Only an appliance, repair parts store can answer those questions. Look in phone book
Oct 01, 2009 | Cuisinart Supreme Grind CCM-16PC Grinder
Need wiring diagram for 1999 gmc tail lights
I'am going to go out on a limb hear and assume that you need this due to the fact your tail lights quit working. This is a very common problem, and the circut board in the tail lamp seems to be the main problem in these. Most parts stores carry these at all times. If you need for other than this problem- please clarify
Aug 29, 2009 | 1999 GMC Sierra
WHERE DOES THE SUBWOOFER SPEAKER CABLE ATTACH TO ?
the incoming wires go to circut board.the sub wires will also come from the circut board im sure if opened you will see where they were solidered on
Jun 10, 2009 | Audio Players & Recorders
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Sep 04, 2007 | Ovens
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
