Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
