Question about Brother DCP-110C All-In-One InkJet Printer
Black ink full won't print on pages
Hi. I moved a few weeks ago. I was super careful with this printer.
When I hooked it up, it wouldn't print. Kept telling me I needed ink replaced==
not black one, 2 others. Took awhile to figure out how to reset that as neither was even slightly used.
So now I have important paperwork and someone coming here to sign it
and I can't get it to print.
How do I trouble shoot it?
Thanks
Beah
  • 1 more comment
  • bbchris2 Aug 04, 2008
    Black won't print.  Changed all ink cartridges, other colors print but not black.
  • prpl Sep 06, 2008
    The printer printed great until I got my first "near empty" message. I've changed all the ink and I still get the message and printing is horrible. I've used the clean option many time too. I don't know what to now. Help!
  • JodieTara Sep 08, 2008
    my brother dcp-100c worked a few months ago before i went away. i came bk two weeks ago, and have recently found that my black ink does not print. i changed the cartridge to a full one and it still does not print out documents in black. if i go to my properties for my document, and set it to black, it comes out in colour. my colour ink is working fine, and the printer even registers my black ink as full on the ink management but im soooo confused. ive cleaned the inside where the cartridges go many times, ive got the printer to clean the ink at least 20 times. i just need a solution!
  • Brother Master
  • 4,338 Answers
Here is resource page and "No cartridge " error info:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
  7. Good luck, Joe
  8. Please remember to rate all Techs who assist you for free :)
Posted on Oct 04, 2008
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
New ink cartridge only last less than two weeks after printing less than 30 pages
I had that model and the same experience. I kept buying ink until I realized I could have nearly bought the printer for nearly the same cost as ink refills, black and color. I also had an HP. Same thing. I finally bought the Kodak 3250. The ads about ink costs was so correct. Many more pages are printed before the "need ink" message is displayed. Buying ink online saves even more.
Mar 27, 2012 | Canon PIXMA MP150 All-In-One InkJet...
I have a Brother MFC 790cw that does not print black all the other colors work, I have updated the driver bought a new ink cartrige and used the the clean option for the black ink. I know it is recieving...
Try printing a rest page and if that doesn't print in black ink the printhead is probably blocked.
With some printers the printhead is part of the ink cartridge and such problems tend to disappear when the cartridge is replaced, unless the cartridge is faulty. Other printers use cartridges that are ink and nothing more and those are prone to the printheads drying out and becoming blocked unless they are never allowed to become completely empty of ink and are kept in frequent use.
Cleaning/replacing such a printhead usually needs special tools and experience and in the case of many cheap domestic printers the cost of service far outweighs the cost of replacement.
Aug 13, 2017 | Brother MFC790cw All-In-One InkJet Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
Printer has been idle for several weeks.When I came to use it the printing is broken and faded looking.How do I clean the cartridges?
HP Deskjet 5550 Printer.
The deskjet printers should not be kept idle.
At least once in two or three days, you can take one page print out.
This has to be done, otherwise, the inks both Black and colour will get frozened and sometimes it will become dry at the catridge mouth.
Black Ink is 56 and Colour is 57.
Solution :
01. Manually remove both catridges from the printer carefully.
02. Shake the catridges with full force pointing towards ground. You can find out now, that ink is coming out from the catridges which was frozen or dried up.
03. Clean the cartridge drive with a nice cloth and cleaning liquid.
04. Re install both catridges and take a test print out.
05. Recommended to have a service contract with local HP Authroized printer vendor to have a regular maintenance at least once in a month.
Jul 21, 2009 | HP DeskJet 5550 InkJet Printer
Ink low indication on HP Deskjet F4288
hi im josh in cebu phils.may i help you? Friend the problem is the ink level dropped 3/4 after printing 7 pages and low exclamation mark in red. Friend it is the real deal since you are using a free ink cartrdge with your printer that ink is only a sample one and the content of that cartridge is not full thats why it dropped to empty in just a few pages of printing. It just appear full in the ink level monitoring since the printer auto detects new cartridge on the tank. It is just so You need to buy a new ink cartridge the one with the full content.and i'm sure it will last a long time since it is already full. thats all friend good luck hope i helped you.
Mar 14, 2009 | HP Officejet Pro L7680 All-In-One Printer
Wont print black
clean the contact on the printer and the ink cartridge. do not use paper towel. use coffee filter.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
269 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
