Question about InFocus Proxima UltraLight X350 Multimedia Projector
LAMP BULB REPLACEMENT PROCEDURE
Hi. I was wondering if anyone knows the procedure for replacing the lamp bulb on the Ultralight X350. The X350 has wording on it advising the user to refer to owners manual. When I do, there is nada. I am concerned about opening it up since there is a warning saying the bulb is under pressure and may explode if not handled properly, etc. Would appreciate anyone that may know the procedure, i.e. get a blowtorch face mask for protection, etc. Best Regards - Ray
  • 2,236 Answers
It's only under pressure when it's very hot. just wait for it to cool down (about 30 minutes), drop the elevator foot, remove the 3 screws, and remove the lamp. replace and reverse instructions.
Posted on Sep 04, 2009
Tv turns off for a minute and comes back on
if tv turns On itself after shuts down then its symptom of weak lamp as current lamp is reaching to end of its working life, tv requires lamp replacement.
Lamp replacement procedure would be written in user manual and its easy. Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bulb keeps going on and off . does that mean the bulb is going bad
If TV shuts off and turns On itself again then yes, bulb in TV is weak and need to be replaced.
Please buy Sony oirignal bulb/ lamp for your TV safety.
Lamp/ bulb replacement procedure would be written in user manual.
Thanks.
Jan 01, 2010 | Sony KDF-E55A20 55 in. LCD Television
How do you replace the tail light bulbs on a 2006 Pontiac Vibe
Tail Lamp: Service and Repair
TAIL LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Open the rear compartment lid.
2. Remove the rear compartment trim panel (4).
3. Disconnect the tail lamp electrical connectors.
4. Remove the following components from the vehicle:
- The 3 nuts (3)
- The tail lamp (7)
5. Remove the following from the tail lamp:
- The stop lamp socket (2)
- The turn signal lamp socket (5)
6. Remove the following from the lamp sockets, if necessary:
- The stop lamp bulb (1)
- The turn signal lamp bulb (6)
INSTALLATION PROCEDURE
1. Install the following to the lamp sockets, if removed:
2. Install the following to the tail lamp:
3. Install the tail lamp (7) to the vehicle. Secure the tail lamp (7) with the 3 nuts (3).
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp nuts to 10 N.m (89 lb in).
4. Connect the tail lamp electrical connectors.
5. Install the rear compartment trim panel (4) to the vehicle.
6. Close the rear compartment lid.
Oct 30, 2009 | 2003 Pontiac Vibe
How do you replace reverse bulb on 2001 deville?
2001 Cadillac DeVille V8-4.6L VIN 9
BACKUP LAMP REPLACEMENT
REMOVAL PROCEDURE
1. Pull down the rear compartment lid trim. Refer to Compartment Lid Trim Replacement - Rear in Trunk/Liftgate.
2. Disconnect the electrical connector.
3. Remove the fasteners that secure the backup lamp assembly.
4. Remove the backup lamp assembly.
5. Remove the bulb assembly.
6. Remove the bulb.
1. Install the bulb into the bulb socket.
2. Install the bulb assembly into the backup lamp assembly.
3. Pull the wire harness through the body and seat the grommet.
4. Install the backup lamp assembly to the rear compartment lid.
5. Install the fasteners in order to secure the backup lamp assembly.
Tighten
Tighten the fasteners to 4.5 N.m (40 lb in).
6. Connect the electrical connector.
7. Install the rear compartment lid trim.
Sep 11, 2009 | Cadillac DeVille Cars & Trucks
I have a projector that is powering up but there is no light coming from the lens. I changed the bulb and still the same thing. When it powers up it sounds almost like a harddrive inside is skipping...
the colorwheel may be bad. if the colorwheel doesn't spin correctly, the lamp won't light. turn it on without the lamp in. look inside the lamp housing and see if the multi-colored glass disk (colorwheel) is spinning. if it isn't, or it's laboring, it needs replacing.
Jul 28, 2009 | InFocus Proxima UltraLight X350 Multimedia...
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
InFocus Proxima UltraLight X350 Multimedia Projector Logo
181 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Juan Carlos Pacheco
Level 1 Expert
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
