Belt Installation, Aerostar 4.0L Engine
Item
Part Number
Description
Drive Belt
N606068
Bolt
Generator
Generator Mounting Bracket
5
8509
Water Pump Pulley
6
6B209
Drive Belt Tensioner
7
N800199
Screw
8
8678
Belt Idler Pulley
9
N802096
Screw
10
19703
A/C Compressor
11
2882
A/C Compressor Mounting Bracket
12
3C718
Brace
13
N806020
Bolt
14
3A674
Power Steering Pump
15
3A733
Power Steering Pump Pulley
16
N800199
Screw
17
N606572
Bolt
18
N620481
Nut
19
8501
Water Pump
20
6312
Crankshaft Pulley
A
Belt Tension Check (See Specifications)
B
Tighten to 40-55 Nm
(30-41 Lb-Ft)
C
Tighten to 24-30 Nm
(18-23 Lb-Ft)
D
Tighten to 21-29 Nm
(15-21 Lb-Ft)
E
Tighten to 40-50 Nm
(30-37 Lb-Ft)
Belt Installation, Ranger and Explorer 4.0L Engine
Item
Part Number
Description
Drive Belt
Generator
Belt Idler Pulley
A/C Compressor
5
3A733
6
8501
Water Pump
7
6312
Crankshaft Pulley
8
6B209
9
N806020
Bolt
10
2882
11
3A674
Power Steering Pump
12
N606572-S2
Bolt
13
N800199-S8M
Bolt
14
N620481-S2
Nut
15
3C718
Brace
16
N606068
Bolt
17
10153
18
8509
Water Pump Pulley
19
N605805-S2
Bolt
A
B
Tighten to 21-29 Nm
(15-21 Lb-Ft)
C
Tighten to 40-55 Nm
(30-41 Lb-Ft)
Belt Installation, Ranger 2.3L serptine belt diagram - q3646c.gif>
Item
Part Number
Description
Belt Idler Pulley
Generator
Water Pump Pulley
3A733
5
2E884
A/C Clutch Pulley
6
6312
Crankshaft Pulley
Belt Instserptine belt diagram - q4740a.gifAerostar 3.0L Engine
Item
Part Number
Description
Generator
3F671
Belt Idler Pulley
3A733
6B209
5
6312
Crankshaft Pulley
6
8509
Water Pump Pulley
7
19703
A/C Compressor
SOURCE: need a diagram of how a serptine belt is installed
Click on the following free direct Link. It has the Serpentine Belt Diagram and Tensioner location for your 1990 Oldsmobile Ciera, depending on your size 2.5L Engine options (AC/No AC, etc.).
GENERAL/Standard Rules to Removal the Serpentine Belt with a Tensioner:
A. Find the Tensioner(s). (See Diagrams on Link)
B. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
C. Remove the loosened belt off one of the other more easily accessed Pulleys.
D. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with Tensioners:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/1990/make/oldsmobile/model/cutlass_ciera/1990_oldsmobile_cutlass_ciera_drive_belt_routing_diagram.htm
SOURCE: diagram to change serptine belt
Hi. Your Ford Taurus has 3 engines. They are V6 3.0L 182ci FLEX FI N 2, V6 3.0L 182ci GAS FI N S, V6 3.0L 182ci GAS FI N U. I am not quite sure what engine is yours. Anyway, i provided you a link where you can fint all these engine belt routing diagram. Pelase click here.
All the best!
SOURCE: I need a diagram on the serptine belt on a 2000
It will depend on the engine type you have in the vehicle. One image is for the 2ZZGE engine type, and the second image is for the 1ZZFE engine type.
