Question about Akai PT4298HD Rear Projection Television
Akai 1080i The picture looks like you need 3-D glasses to watch and get the picture to come together. We don't have an Akai repairman in our zip code. We bought the TV from Costco 4 years ago and this has been a problem for the last year. HELP!
  • 2 more comments
  • Anonymous Aug 05, 2008
    My akia did the same thing about 3 weeks ago and I can't find anyone who will come out to fix it!!!
  • sschillaci Aug 12, 2008
    My tv picture is blury along the edges. When the self focus comes on, it says "check factory data." How do I check "Factory Data?"
  • queenster71 Aug 15, 2008
    I am having the same problem with my akia tv. I called a repairman, he is coming to my house tomorrow. I will repost to let you know what is wrong with it. I just hope that it won't be that expensive to fix. The tv is only three years old. grrrrr........
  • Anonymous Apr 08, 2009
    I have a PT4298HD. I moved the TV from one side of the room, to the other. Now, the convergence is off and the picture bows to the middle of the screen.
Buy a new tv
Posted on Aug 07, 2008
I took the back of the tv off and the blue lamp is not bright like the red and green. Could this be a coolant problem or lamp. I have the PT5492S Akai rear projection TV.
The blue is usually dimmer than the other two lens; what I would suggest is try to look into the lens with the set on; BE CAREFUL AND NOT TOUCH ANYTHING INSIDE THE SET.
If the red and green show a picture but the blue looks like a floodlight you have bad Glycol in the blue tube (common in these sets).
If all have a normal picture remember to wipe the lens clean at the top; do not try to take the lens etc apart.
Before you rate this information let me know what you find.
SD TECH
Aug 15, 2011 | Akai PT5492S 54" Rear Projection...
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have blue ghosting in our TV picture
if the picture looks kinda 3-D
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases you may need to open the set and tell them what the STK numbers are on the chipsGOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 06, 2009 | Akai PT4298HD Rear Projection Television
PT4298HD Double image
BINGO thats exactly what i get paid to do same price 285.00
Nov 30, 2008 | Akai PT4298HD Rear Projection Television
Sony Hi-Scan 1080i 52" projection TV colors won't converge
No you will need to repace compents. Do you know how to solder and use a meter? If so I can assist you with the repair. If not you will need a repairman, he will cost you about $300-$500 for the fix.
Tim Nolan
Sep 13, 2008 | Sony KP-53HS20 TV
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Auto Focus Stoped Working
    If the convergence is very far off the convergence ICs are bad and need to be replaced first. If the convergence is close and it wont correct it might just be an insect or some dust on the sensors at the 12, 3, 6 and 9 o'clock posistions behind the screen.
    Jun 04, 2008 | Akai PTH5498 54" Rear Projection...
    Pitcture is Wavy
    Sounds like the tuner is going.
    Dec 05, 2007 | Akai PT4799HD Rear Projection Television
    AKAI 1080i HDTV 42"
    · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    · http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Aug 27, 2007 | Akai PTH5498 54" Rear Projection...
    Akai PT4298HD Rear Projection Television Logo
    257 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
