Question about Microsoft Xbox 360 Console
VGA Cables Can a Xbox 360 be connected to a HP Pavillion ze5300 Laptop computer via VGA cables?
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
No. the video only goes out not in...sorry
Posted on Jul 31, 2008
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
Hp pavillion ze5300 need to get into CMOS can't
There are a few ways to attempt this one is take it in to a shop they can access it with special software. Or download your own special crack software or re-install you operating system using the recovery disc that came with your laptop. Try removing the CMOS battery as well for about 10 minutes or so. Sometimes this will work Also call them they have bypass codes they use to get your through as well. My suggestion would be to call them and have them walk you through it and explain it further if your not computer swavy.
Apr 14, 2012 | HP Computers & Internet
Lagging on a xbox 360 with a 320gb hard drive
It is not only the memory to check when your xbox is lagging. You need to check if you are connected wirelessly for it might be interferrences issues. You need to connect via ethernet cable first to isolate wireless issue. Once connected via ethernet cable and still lagging you can check the bandwith issue. Make sure that when connected to your computer/tower, its only the xbox in use. Turn off any computer, laptop, any wireless device that might be using the internet.
Dec 21, 2011 | Microsoft Xbox 360 Console
Im trying to hook one of these up to an xbox 360, is it possible to do so via hdmi cable, or just via vga?
hi if you have an xbox elite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
Feb 22, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
Xbox won't connect to live through my laptop
When you connect the laptop to the router are you using a network cable?
When you connect two computers such as your laptop and the xbox using a network cable you need a crossover cable not a standard network cable.
If you use a network hub you can connect two or more computers together using the standard network cables.
Jul 28, 2009 | Microsoft Wireless Network Adapter Xbox...
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 live using internet through my laptop
Normally you would connect your xbox directly to the router. Is there a reason you are trying to connect to your laptop instead? (distance, etc.)
If that is what you truly want to do then first thing make sure you are using a CROSSOVER cable to connect your laptop and xbox together. standard network cables only apply to connecting to routers, switches, and other network controlers. If you are connecting two devices directly you must use this type cable. It is ussally red.
The share tab is only for sharing dialup connections to LAN connections. You are sharinbg two LAN connections so all you need to do is bridge them and make sure there are in the same IP group. Check the status of your wireless card to see what address the router is assigning to it. Then assign the IP to the wired adapter with a differnt higher number.. Example: If your wireless card is 192.168.1.100 then make your wired adapter 192.168.1.151 This should make it work.
Again, it would be much easier to connect your XBOX to the router like it was intended ;)
Jan 03, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
