I have a 6 year old Halstead Ace High boiler which has many recurring problems due to a bad fitting. It was never flushed out causing the heat exchange needing to replaced TWICE through clogging and then there were problems with the inflation device so a new one was added to the exterior of the boiler. Now the pressure won't repressurise past 0.5, there is no sound at all when the valve is turned. Hot water comes and goes with the boiler switching itself on and off after a few minutes so showering is usually a very streeful and chilly experience! Have spent so much on it but it never seems to work for long. The water pressure is low in general as we share our water with our restaurant downstairs although they have their own boiler. The house has a shower room, one bathroom and 2 kitchens. If someone is using water elsewhere in the building then there is little if any water available to use until they finish. I have been offered many different solutions, all of which are way over my budget: replacing the boiler with a new one, adding an extra boiler, getting a seperate water supply fitted... I'm at a loss what to do, please help!!
Firstly your system needs a power flush to get rid of the grot, then it needs a good inhibitor to slow up the reappearance of the sludge.
Changing the boiler won't help. Any boiler will get clogged up but the halstead DHW heat exchanger is particualrly prone to getting gummed up. You can clean this out and refit without having to buy a new one. - but without a power flush it will happen again.
Posted on Apr 16, 2009
Hi, my halstead ace high boiler has started losing pressure and when i top it up to put the heating on after 10 mins the pressure is high whats wrong with it?
Probably a waterlogged expansion tank. The tank provides a springy air cushion for the water to push against as it expands, and the air pushes back as the water contracts. This scheme minimizes the pressure change that would otherwise be caused by expansion and contraction of the water, giving the water somplace to go when it expands. If the air cushion is gone ... big pressure swings.
Dec 28, 2009 | Water Heaters
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Nov 30, 2009 | Water Heaters
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Open vent central heating
yes it is possible toupgrade the system to a sealed one using a system boiler as you mentioned. the thing to bear in mind is to upgrade the radiator valves to pressure rated ones 10bar.
The probable cause of the over heating is down to the system being sludged up/cold feed blocked, or possible pump circulating problem?
I would recommend the installation of a magna clean filter to help keep the new boiler clear from system debris.I would definately power flush the system, if the system is a twin two port valve system then a automatic bypass should be fitted, all of this done by a corgi registered gas engineer
Kindly
Richie
Dec 18, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Heating & Cooling Logo
615 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
