Question about Carrier Heating & Cooling
Air conditioner model #xcb183 - motor runs but not cooling
  • 230 Answers
SOURCE: blower motor in home air conditioner does not work
The most common failure for this problem is either the start/run capacitor or the fan motor. IF YOU ARE NOT experienced with electricity then I would strongly suggest hiring a technician. The volts are 220 with a potential of 50 amps in a common residential unit.
If you are knowledgeable in this area then make sure the motor has volts to it. If it does have volts and does not spin, it is bad. You can sometimes tell by feeling the motor it will probably be very hot. The compressor will eventually shut itself off when it over heats. It usually will restart after it cools down(sometimes many hours). The motor and capacitor are pretty generic and can be matched up at a local Grainger store or whatever Retail, specialty store that you have in your area.
I hope this helps:)
Posted on Jun 25, 2008
  • 393 Answers
SOURCE: Dometic Duotherm air conditioner -Model #57915622
check the thermostat
Posted on Nov 16, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 17 Answers
SOURCE: Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
Posted on Jun 03, 2009
SOURCE: Air conditioner constantly running, not cooling house
Ours was worse than yours. It was not frozen up, but it did need freon. The tech told us that the compressor coil (the unit in the attic) was leaking freon and that the unit would have to be replaced within a year, but adding freon dropped the temperature inside from the mid-80s to the mid-70s (on 100 degree days). It might go lower, but we don't set the thermostats below 76. We paid $80 for the service call plus another $197 for 3 lbs of freon (for our 4-ton unit). Total cost: $274. The quote to replace the system with a new 14 SEER unit is $7,000 -- but this will get us through the summer. Oh, be sure to replace your filters monthly and keep your condensor fins clean. Spray them down with a hose (even while the unit is running), make sure there are no leaves or other trash blocking them, and make sure you have 2 feet of clearance around the condensor. Putting plants or other objects right up against it will impede its operation. Good luck!
Posted on Jul 04, 2009
I have a Dometic Duo-Therm model no. 59516.531 AC. The fan runs slowly and the seems to run but doesn't cool because the fan doesn't run fast enough. Any help on where to start?
try testing the capacitor for the fan if there is one. if there is multiple speeds on the fan motor see if it is getting the correct voltage to the motor if it is getting reduced voltage it will cause it to run slower. U can find the max voltage on the side of the motor and just test the motor by making up a lead if u can.
May 22, 2014 | Dometic Rooftop RV Air Conditioner
I have a continental elec port. air. Not sure of model. Cools great but when compressor kicks on unit make a loud whistling noise. Cleaned filter no help.
although annoying, at this time i would not mess with it, the fan motor needs oiling (zoom spout oiler ) works the best .. you can find how in my other postings.. try running the unit on a lower fan speed... some cool is better than NONE
Jul 28, 2011 | Continental Electric Portable Air...
I have a 6 year old Goodman ClJ24. Today I noticed that the motor in the unit was running backwards.Instead of blowing out hot air from the top, it was sucking in air. Also unit suddenly is not cooling.
Yes, once in a while the motor will just start to run in reverse...this is not fixable... you will need to replace that motor...and as you can see if it is not running correctly you will not get proper cooling...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 15, 2010 | Goodman CKL24AR24 Air Conditioner
Fan motor
I may be that your filters or cooling coil is dirty too. Usually when a fan motor goes bad it simply doesn't run.
Jun 02, 2010 | Maytag M7D24E7A Air Conditioner
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Goldstar model number wg1205r AIR CONDITIONER, NOT COOLING
thermal relay is not functioning , u need service technician
May 15, 2009 | Heating & Cooling
Heating & Cooling Logo
110 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
