Question about Texas Instruments TI-30XA Calculator
The number e
Is there a way to find the sum of something with the number "e" without having to enter the value of "e" which is approximately 2.718281828459?
E to the first power is 2.71...
Press the following buttons in sequence: 1, 2nd, LN, + and then your numbers.
Posted on Sep 06, 2008
Create javascript code whose function is to compute the sum of two inputs?
The following code will dynamically calculate the some of the first two fields:
Enter first number:
Enter second number:
Their sum is:
Best Regards, Ben
Jun 29, 2011 | Computers & Internet
How do you find the standard deviation?
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Feb 16, 2011 | Casio FX-115ES Scientific Calculator
I don't know anything about physics or statistics or anything like that so I cannot do a test problem. :-( But I am in physics now and the professor said we needed a calculator that can do 1 and 2 variable...
Do not go buy another calculator because this one does 1-var, 2-var, as well as some regression models, and some distributions.
For 1-var and 2-var statistics read on.
Jan 22, 2011 | Casio FX-115ES Scientific Calculator
How to solye statistics problem
I have no clear idea what you mean by solve statistics problem. But if your problems involve finding the standard deviation and other statistical values then this post will help you.
The variance is the square of the standard variation
for 1-Var statistics
Dec 22, 2010 | Casio FX-115ES Scientific Calculator
How can i use casio 991ms to solve all statistics questions
first off you want you calculator in SD (standard deviation) mode to do this hit mode twice and then 1.
next it is good practice to start off by clearing the memory to do this hit shift, CLR,1 and then = this will clear statistical memory
to enter values into your data set , you enter the value, then press the DT (M+) button. (note: pressing DT repeatedly will impute the same value multiple times)
once you have finished pluging in your numbers your calculator can give you statistical information about the data set.
hitting shift then 1(S-SUM) gives you three options: 1 the sum of the squares of each value 2 the sum of each value 3 the number of terms in the data set hitting shift then 2 (S-VAR) gives you three more options 1 x bar (the mean) 2 x sigma n (the population standard deviation) 3 x sigma n-1 (the sample standard deviation)
you can use these tools to solve alot of statistical problems i hope this helped
Source: http://support.casio.com/pdf/004/fx115MS_991MS_E.pdf page 28 of he pdf
Dec 01, 2010 | Casio FX-300MSTP Scientific Calculator
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
How to calculate standard deviation
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
HOW TO PROGRAM ARITHMETIC ALGORITHM( ADDITION)IN C++
above int main () you will want "using namespace std;" without quotes. Under that, "int main ()" without quotes, then a [ bracket to start the main function.
Please rate, thanks!
Mar 16, 2009 | Computers & Internet
Sum function
Write down the number in cells for Example:
A1 (59)   Without Brackets
A2 (50)
A3 (80)
A5  ?    ANY Number
A6  ?    ANY Number
A7  ?    ANY Number
A8 =SUM(A1:A7)     you will get total sum of above numbers on                                   this A8 Cell which is auto sum whenever you                                 change the value on above cell.
Feb 22, 2009 | Microsoft Computers & Internet
Texas Instruments TI-30XA Calculator Logo
88 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
