Question about Canon ZR80 Mini DV Digital Camcorder
Zr80 camcorder when I put a tape in the recorder, the camera begins to load and then it pops open
  • liuguduke Aug 25, 2008
    I have the same problem. When I tried to load a DV tape to my ZR 80, it did not take it and displayed a message: Remove the cassette, with a warning beep. I tried several times and used new tapes, but nothing worked. I have bought the camcorder about two years, but just used five cassettes on this camcorder. It has stopped working. Is there anything that I can do?
  • Brennasmatt Sep 14, 2008
    I am having the same problem. I sent my Camera in for service about 1 year ago because of a failure to display anything on screen. It worked fine for about a year and then.... this.
Push down where it says "Do not push down here"!
Posted on Jan 28, 2009
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Canon zr300 ejects tapes
http://www.fixya.com/support/t985270-cassette_loading_problem_in_canon_zr200
I "smacked" my ZR300 as instructed on this site and it worked. Good luck!
littlequeen
Nov 02, 2008 | Canon ZR80 Mini DV Digital Camcorder
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
On playback, the video has gray lines across it
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Gray lines on playback
Try using an $8 head cleaner for 10 seconds. That might be the solution or if it's a used tape, the speed isn't limked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that.
Dec 26, 2007 | Canon ZR60 Mini DV Digital Camcorder
Camcorder ZR80 saying remove cassette, won't record or play.
when you put cassette try to see the take up left side weather it rotating?if no try to rotate with your finger.may be there is a bend on that.
Nov 25, 2007 | Canon ZR80 Mini DV Digital Camcorder
Hello - Canon ZR80 - auto shut off
If you're trying to use the camera as a webcam, just remove the tape. The auto power-off is a safety for keeping the tape from getting damaged.
Nov 18, 2007 | Canon ZR80 Mini DV Digital Camcorder
Horizontal lines on playback screen
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon ZR80 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
