Question about HP OmniBook XE3 Notebook
HP Laptop I have an HP Omnibook about 6/7 years old. I want to get a new laptop hhowever i am not knowlegeable about transfering info from old computer to new one.
    New Friend:
  • 40 Answers
Hp is also good choice but try to buy from reliable source. You will find powerful features . im using used laptop and brand is hp .
Posted on Jun 24, 2015
  • 147 Answers
There is many way to transfer data form laptop to other...
1. you can use any external USB device copy all data and then attach in new laptop.
2.Make a cross cable then connect both computer and you can move all data easily form one to other.
3.Enable wi-fi both laptop and connect and share all data
4. http://www.microsoft.com/windowsxp/using/setup/getstarted/bott_fstw.mspx
Posted on Jun 26, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
You can connect both the laptop using the firewire cable and tranfer the data from old laptop to new one
Posted on Aug 18, 2009
How do I upgrade the Intel Pentium 4 CPU in my omnibook xe4400s; thanks reastonmd@cox.net
No, this is a mobile processor, see spec here. HP Omnibook XE4000 and HP Pavilion ZE5000 Product Features and...
it integrates with the laptop for saving battery power and the chipset.
To speed it up, put in a much ram memory as allowed,.
Defrag the hard drive to speed it up.
Check your drivers are up to date, this may speed it up.
Feb 12, 2015 | HP OmniBook XE4400S PC Notebook
HP Omnibook 6000 Laptop Noise
It could be the fan which may have a noisy bearing.
Jun 26, 2012 | HP OmniBook 6000 Notebook
Where is the model number on an Xe3 omnibook laptop/notebook?
Wow that's an old notebook. Normally if you look on the bottom of the laptop it will give you the model number. But all you need for yours is the fact that it is an Xe3 Omnibook.
It has 2 memory slots and will only hold a maxium of 1 GB of memory which is 512mb in each slot.
Here is where I got that info below.
http://www.4allmemory.com/memory/compaq-hp-omnibook-xe3l-series/
Apr 26, 2012 | HP Computers & Internet
Which webcam should i buy to use on my nx6325? all the newer ones seem to lag as the graphics card looks too old for them?
You could get better performance with more RAM, but since the laptop is old I suggest you put your money towards a new laptop.
You could remove the hard drive from your old laptop and insert the hard drive into an USB hard drive adapter case and use it as an external USB hard drive for backups and file transfer.
Apr 18, 2012 | HP Compaq nx6325 Notebook
How do I replace (access) the Hard drive in a HP Omnibook XE3?
6ya, wakes this up from 6 years ago
but here is answer, see these 3 spots
1 is hdd, for sure.
just like lets make a deal, door #1,2,3
the bottom door 3, is battery ,
xe3-4s4zmhj3prccinjirhq2melp-2-0.jpg it may not, its PATA drive back in the dark ages of LT.
with a huge wide connector. Ribbon cable to match.
it has 90deg, connector to the MOBO,
ok thanks to Ebay, we can see all the parts
it has HDD PATA drive CADDY
as seen here.
my take whole case split to reach it.
the stap is to yank it fee of mobo after unbolting it. x4
caddy-4s4zmhj3prccinjirhq2melp-2-1.jpg end dark ages.
Aug 10, 2010 | HP OmniBook XE3 Notebook
I have the hp omnibook 500 plugged into the wall but im not getting in response, do i need to have anything else plugged into the laptop
if the charge light doesnt turn on on the computer ..then you may have a broken wire from the charger .. that happens frequently right at where the wire enters the plug that plugs into the computer .. someone thats knowlegable about polarity and soldering can replace the tip .. or you could get a new charger ... if the charge light does lignt steady on the computer then thats not the problem .. often it is ..
Nov 12, 2009 | HP OmniBook 500 Notebook
21/10/09 Hallo. Re.: hp Omnibook XE2. Upgrade hard disk drive 20 GB or 30 Gb. I would like to know if some one has installed a 20 GB or 32GB hdd and if he has any problems with that. I would like also to...
the HDD best to use is an SSD.
the HDD was a standard, 2.5? PATA drive for laptops
why would you want such a small drive, they dont make them now. (40 smallest?) new.
this PC is not supported by HP now, its too old a Pentium III no less.
why would 20gb be and upgrade.?? 10 now? omg , it is 10GB...then... and worse its PATA (IDE) harddrive.
its 17 years old now, most are in the recycle bin,
it came with windows 95 or 98, (hopeless that OS)
the laptop has zero value now, so is putting a new
$50 to 100 dollar drive,is wise,?
what if there are more problems, (endless when that old)
you can not use modern, SATA drive (
just 2.5" PATA (IDE) (pata is wide parallel interface with wide ribbon cable)
here are some
http://www.pricewatch.com/price/hard_removable_drives/notebook_40gb
Jul 18, 2017 | HP 80GB NOTEBOOK HARD DRIVE KIT FOR HP...
Omnibook 6000
You need to purchase PCMCIA wireless card, because Omnibook 6000 not have built-in wireless card.
Sep 15, 2008 | HP Omnibook CPU Cooling Fan CPU Fan,...
Model of modem use in hp omnibook xe4100
Check out Connexant HSF-Softmodem and VIA VT 8501 MVP4 Modem.
May 17, 2008 | HP OmniBook XE4100 Notebook
Turn LAPTOP ON
push the screen to you and push it away so far as he can.
you hear a click the screen is fixed
May 14, 2008 | HP OmniBook XE3 Notebook
HP OmniBook XE3 Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
