Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
Help! need manual lost it trying to get headboard together
Hi, I had the same problem and called 1-800-858-8323 and they e-mailed me the manual!
Posted on Aug 07, 2008
I need replacement bolts for a Pottery Barn king Sumatra Bed.
It is very likely they are metric threads. 6 or 8 mm are most likely.
These thread sizes come in two different thread pitches (fine and coarse). Buy a mix at a small hardware store. You could even bring the headboard with you and a friendly associate might bring a handful out to the car with you to test which one fits.
Sep 04, 2014 | Baby Gear
Need replacement parts
I need replacement parts for the buzz light year toddler bed. I am in need of both wings that connect to the headboard. I'm also in need of the screws and bolts to attach bed together. You can text me @ 304-617-3207 or email me back @ daniels165@live.marshall.edu.
Thanks in advance. I hope you can help us.
Dec 17, 2013 | Thinkway Toy Story Buzz Lightyear Space...
INSTRUCTION MANUAL FOR PHOENIX BOOKCASE BED
its not hard.. you need the allen wrench. start by removing the planks (unscrew with screwdriver). then the two side drawers (allen wrench to unscrew, then lift/unhook). should result in all three drawer sections separated plus the 4 connector boards. last is headboard - be careful - top piece with the two small drawers separates from it's stand/part of the headboard. if you cant get someone to hold it still while you uncrew w/allen wrench, just take your time unscrewing and breathe lightly :)
Nov 09, 2013 | Coaster Furniture
Trying to assemble the trendwood high Sierra bunk bed
Contact the company and ask for the install info.
http://www.trendwood.com/bunkhouse.html
This does look simple.
The bottom head boards look like a H, and the top look like a A.
Now you know you need two H headboards, two long sideboards, and the drawers for the bottom.
The top has the same sideboards as the bottom but there is a smaller one also.
I don't know if the headboards came assembled but if they did, all you do is put the long sideboards up to the headboard and place the bolts through the headboard into the sideboard.
Go to the website I posted, click on the high sierra picture, you can see what it looks like.
Apr 13, 2013 | Furniture
How can I attach a hook-on headboard to my bed frame?
In order to attach a hook-on headboard to your bed frame you need to use a bed hook adapter, it will attach easily to your headboard bracket.
Aug 23, 2012 | Acme Furniture
I bought a kinderkraft crib used and it came with the hardware, but no instruction manual. Can I find assembly instrutions online?
  • I can tell you how to assemble it.
  1. Place an insert nut into the top of the stationary rail.
  2. Place another nut into the bottom of that same rail.
  3. Flip that rail over and put another nut into the top and bottom of it the same as you just did.
  4. Now stick a two bolts into one side of the headboard.
  5. Stand up the headboard and twist them bolds from the headboard into the stationary rail.
  6. Now you want to twist two bolts through the secondary headboard and through the other side of the stationary rail. Make sure not to tighten them bolts up to much yet.
  7. Now put the mattress support inside the crib.
  8. Take four bolts into the top holes that are pre-drilled in the slat on the headboard and then on through to the mattress support.
  9. Do the same now with the other slat support for the headboard.
  10. Now do the same with the two remaining slats for the secondary headboard.
  11. Now tighten all the bolts real well.
  12. Put the crib on it's side.
  13. Now your gonna stick the canisters into the legs. Tap them in with a hammer if they are a bit stubborn.
  14. Now slide the rubber off of the lower side bracket.
  15. Hold the front drop rail so that the push plate faces away from the crib.
  16. Now slide that front drop rail on the tracks until it is all the way in the crib and then reinstall the rubber stoppers.
  17. Now put the crib on it's casters and go over the crib and give it a once over and make sure everything is secure and tight.
  18. Crib is ready to use now.
Regards, Tony
May 02, 2011 | Toys
I have a canton 4-1 crib but have lost the manual on how to assemble it into a full size bed,does anyone know where i can obtain this information,thanks
Are you sure you lost the manual? It took us all day to discover it was attached to the crib base under the mattress. We have a different simplicity crib but it needs either rails or you buy a full-size bed frame from a mattress store and attach it with the headboard adaptor plates and screws they gave you.
Jan 01, 2011 | Simplicity for Children 4-in-1 Convertible...
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
Simmons crib assembly problem
The necessary hardware should be listed in the assembly instructions. If you don't have those, then contact Simmons at 800-218-2741. All you need is the model number, which should be on the headboard, and they should be able to help you out for a nominal fee.
Jun 13, 2010 | Simmons Mattress Crib 'n More
HAVE AN OLD BABY BED & NEED TO KNOW HOW TO PUT IT TOGETHER? 32 YEARD OLD - SIMMONS BABY BED
Please give the model number. It is usually on a sticker on the inside of the headboard. After that manuals/instructions are easier to find.
Apr 16, 2009 | Kinderkraft Vermont Crib
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
Top Simplicity Baby Gear Experts
Charles T Nevin
Charles T Nevin
ray gallant
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
