Question about Brother XL-5130 Mechanical Sewing Machine
Bobbin compartment trouble
I'm trying to figure out how to put the pieces back together. I'm sewing machine challenged! I have pics!
Here's the story- I must have loaded the bobbin the wrong way. Everything fell out. So now I have the bobbin, the thing it goes in and is placed in the machine, a ring looking piece, and a piece that has the bar that the bobbin slides onto.
  • 202 Answers
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Posted on Jul 31, 2008
HELP PLEASE!!!! Need to figure out how to fix a Singer's Sewing Machine's drop in bobbin casing for my Singer 90s Special Edition???
Sounds like bird nesting or thread nesting (a user error), where there are thread "barfs" under the fabric. This is caused by the top thread not being seated in the tension disk. Remove the thread from the machine. ALWAYS RAISE the presser foot when threading the upper thread!!! Rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low numbers--you'll probably need to tweak it for your particular machine.
Remember, when experiencing problems, install a brand new needle. Remove the thread from the machine, RAISE the presser foot, and rethread from the beginning.
It also helps to always pull the bobbin thread to the top of the fabric, gently hold both thread tails in your left hand, and then slowly take the first couple of stitches.
Understanding Thread Tension Threads
Mar 10, 2017 | Singer Sewing Machines
Need a bobbin diagram for elba tx electronic so I can put it back together
It would probably be better to just purchase a brand new bobbin case. A bobbin case is a very technical piece of equipment vital to the successful operation of the machine. Even if you get it back together, it requires some very finite adjustments to make it operate properly.
Nov 19, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
Complete bobbin case apart...how to fix it ?
Hai, First you should learn and try to your old machine how to operate the machine? After you started to operate a new machine. Then first you check the timing and change the bobbin case and needle.
Mar 24, 2014 | Brother LX3125 Sewing Machine
Put bobbin parts back together
What machine are you using?
Jan 28, 2014 | Sewing Machines
Brother 1100 threading the bobbin
try changing the needle
rethread the machine top and bobbin
make sure to use every thread guide
make sure the top thread has not come off the thread take up
lever--this can cause the sewing machine to jam
if it's a top loading bobbin--take the bobbin out of the bobbin case
and turn it around and reinsert the bobbin
if it's a side or front loading bobbin take the bobbin and bobbin
case out and make sure the bobbin is inserted correctly into the
bobbin case and that the bobbin case is inserted correctly into the
sewing machine.
Nov 14, 2012 | Sewing Machines
We have a Thompson PW-301. I find the instruction manual very had to understand in some instances. I finally got it threaded, but the tension part I had trouble with. Once I figured that out, now it seems...
Here's some things for you to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold on to the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting hung up in your machine.
I hope this help you.
Sep 22, 2009 | Sewing Machines
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Bobbin mechanish
click here or go to the following link by copying and pasting into your browser window.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_3537_threading_Diagram.htm
Apr 15, 2008 | Necchi 3537 Mechanical Sewing Machine
Putting the bobbin back together
You can download the manual from the link below: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_xl3500t3510eus&type2=-1&flang=English&dlid= Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Brother XL-3510 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
341 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
