Belt broke on whirlpool automatic washer. model #LFA5700. How do you install new belt? Do you have to lower the motor to get belt back on track?
    Genius:
  • 1,028 Answers
Usually belt pack will have a diagram explaing how to install belt you must love that old washer last belt drive washer from whirlpool was made in 1986..motor doesn't have to lowered but geearcase does but not all the way down have to remove all braces gearcase bolt with spacer is removed all the way other 2 are loosened enough to get the 95405 belt through the various twist and turns necessary
Posted on Jul 31, 2008
Replace belt whirlpool dryer WED7500VW
remove the front panel on the dryer, get the old belt and take it and the model number into your local shop to get the proper belt, put the new belt around the drum with the groves towards the drum, replace the front panel. on the lower part section of the dryer on the back there will be a panel you remove it see the motor, reach in and place the belt around the pulley on the motor then carefully force the tension idler down towards the floor till you can place the lower section of the belt into the pulley on the tension idler and release the idler. you can now run the dryer, as the drum turns the belt will place itself. hope this helps.
Oct 16, 2016 | Whirlpool Dryers
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
I have a whirlpool washing machine. After taking the back panel off, we saw the belt had come off. each time we put the belt back on and start the machine it works its way off again. how do we get it to...
Normally the motor is below the drum & the belt can be tightened by adjusting the screws which can lower the motor from one side. Best way to adjust the screws for tightening is keep the belt on drum wheel & motor pulley & then lower the motor for adjustment.
sonsunny
Jun 16, 2011 | Whirlpool GHW9100L Front Load Washer
I need to change the belt. Old one broke. Have new one and need to know how to install it. we have no manual. Need a diagram. Please help running out of clean closes....Thank you
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you're sure that you have a model that uses a belt, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144
Most recent top load Whirlpool / Kenmore washers don't use a belt. They use a Motor Coupler between the motor and transmission. If yours is one of these, see the following.:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Nov 02, 2010 | Kenmore 24032\24036 Top Load Washer
The drum won't spin and belt will not stay on
i am sending you this breakdown, perhaps will help you to see if there is anything else broken or if you are missing a step in you installation of the belt. hope this helps.250
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does F11 code mean?
F11 is a code that referes to communication error between the central control unit and the motor control unit. Disconnect power. Check wire harness connections to motor and control board. Check drive belt, visually inspect to see if belt is broke. Check drive motor, visually confirm motor operation. It is possible that if the belt broke it may have slung around in the cabinet and damaged or loosened the wire harness connection at the motor. Try unplugging wire harness at motor and then plug it back in securely. Hope this info has helped. Thanks, Tim.
Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Broken belt
Hi ya,
Replacing the belt on some whirlpool Washing machines.
remove lower access panel. remove the 3 screws securing the pump and remove pump from motor shaft. The pump should drop low enough that you will not need to remove the pump hoses. Once the pump is removed, the belt can be installed around the motor pulley and idler. Replace pump.
Web site and schematics below. You can open them into the whole window and buy parts there too!
thank you Huuum
Please leave a solved rating before you sign out
Jan 23, 2009 | Whirlpool LSQ8000 Top Load Washer
The belt on the washer broke it is a whirpool GHW9400PL4 I have the back off and do not see how to tension the belt
Hello ctwconstruct
Welcome
You said, the belt on the washer broke it is a whirlpool GHW9400PL4 you have the back off and do not see how to tension the belt
At this site you will find all the diagrams on the left side of this page which you can scroll down on and click the one you want to see enlarged .
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504601
Happy to help you.
let me know how you do!
Huuum,
Please remember to leave a rating!
Oct 13, 2008 | Whirlpool Washing Machines
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
