Question about Acer Aspire 5100 Notebook
Modem not detected
I was online (dial_up) and the computer froze..(i believe because somone on another computer tried logging on and booted me off). upon reboot of my computer everything appeared fine, however when i tried to connect to the internet again it said "modem not found". The modem and ports are missing from the device manager. I am having this problem on my acer 5100 series notebook. What are some suggestions to remedy this problem.
  • Acer Master
  • 5,568 Answers
Go to the Control Panel, open the Phone & Modems Options folder, click on Modems, delete the modem listed, restart your computer and if you are ljucky, Win will 'find' new headware and reinstall the software for it.
The 'Win' modems aren't the 'real thing;' they use your main processor, a few components to facilitate connection to the phone line and a program that tells your processor (CPU) how to act like a modem.
You may also have to reinstall whatever dialer you use if it was supplied by your ISP.
There could be additional problems but if they show up, just let us know how they manifested - error messages, etc.
Hmmm, badassgirl?
Posted on Aug 02, 2008
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Windows cannot detect a dial up modem
have u tryed to reboot your modem ( pull the power out )
or the reboot button depends on what modem u using
make sure all cables are connecting
if they are then try testing the cables if u can
update the software and drivers, firmware
Jan 27, 2009 | Computers & Internet
Screeching and crackling sounds emitted by modem as I log on
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=dial+up+modem&x=0&y=0
This is one place to start looking. Good prices. Usually when modems start acting up, it's less of a headache to just replace it.
Jan 15, 2009 | HP Compaq Evo N1000v Notebook
Computer virus
You are doing well.i appears as though memory has failed.to run win xp you should need 512mb. of ram.After reinstalling the ram/memory reboot the computer.go online and go here and doownload dial-a-fix and run it.All should now be well. if not contact me here at FixYa.RICHARDM69 http://www.softpedia.com/progDownload/Dial-a-fix-Download-27328.html
Dec 09, 2008 | Intel i865PE (KD865PERLK) Motherboard
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Modem Drops Connection while I'm online!
Try updating your firmware/software for your modem using this site.
http://www.dlink.com.au/tech/
Apr 20, 2008 | Computers & Internet
Dialup link problem
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 02, 2008 | Paradyne COMSPHERE 3910 Modem
Modem replacement inspiron 2200
Do you have access to another laptop that you could test the new modem in? Sounds to me like the new one maybe faulty :(
Try uninstalling the old one whilst its in via device manager then shut down and put new one in. If it doesnt detect it then its faulty.
Dec 28, 2007 | Dell Inspiron 2200 Notebook
Dial-up: Internet Connection
do your pc have a dial-up modem card?
What's the brand? Go to download the latest driver for the modem and try and see.
If not, right click on my computer icon, go to hardware tab, select "device manage", see does it detect any modem driver or not.
If after installing the driver still the same and can't be detected, most properly your modem is going to "heaven".....
Try to change another modem, see whether it can work or not.
Dec 14, 2007 | Computers & Internet
Acer Aspire 5100 Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
