Question about RCA F36650 36" TV
Channels keep scrolling
The channels keep scrolling. If you go to the menu it keeps scrolling also. Since I have cable I can watch the tv, but I can't use any video games.
  • melvidal Oct 12, 2008
    Same problem with my RCA 36" TV; only way to make it stop is to unplug it.
    Sergeant:
  • 280 Answers
Check for a channel button on the front of the set.. one of them is sticking. Try spraying some WD40 around the front buttons and work each one to make sure none are sticking in..
Posted on Nov 21, 2008
My screen keeps telling me to auto scan channels?
This is for basic cable TV. If you have basic cable, go ahead and let it scan channels. If you have digital cable or anything else and use a INPUT or HDMI or RCA to watch TV then just ignore the scan channels prompt as you have a cable box that handles all that for you.
Apr 14, 2014 | Televison & Video
I need code to activate my tv and channels
You probably need to SCAN the channels.
Connect the signal source to the tv. Either cable or Antenna.
Enter the menu mode on the tv. You can do through the remote.
Scroll down to the signal source. Select the signal source you have connected to the back of set.
Scroll to SCAN in the menu.
SCAN in the channels.
Exit menu mode.
You can now watch available channels.
Feb 09, 2011 | Televison & Video
How do you watch free cable channels on a sony
If you are connecting the cable directly to the TV with no cable box, you'll select Home on the remote control. This will put the menu on screen. Scroll down until you find the Channel Settings option. Set the Cable category to On, Select Auto Program to automatically scan for all analog and digital channels. You can then customize which channels you want to remove when scanning channels.
Feb 10, 2010 | Sony BRAVIA KDL-40V3000 Television
When I try to set our TV to locate digital channels, the menu skips the channel selection when I scroll through options of picture, audio, channel, lock, setup. All the options are available.
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 27, 2009 | Televison & Video
KEEPS SAYNG NOT PROGRAMMED TO WATCH NORMAL CHANNELS
Do a first time installation, move the TV or bite the bullet and either buy an external aerial or extend the main house aerial cable to reach the TV. assuming your TV has no signal where it is now
May 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
The universal remote does not bring up the menu so I can program all the cable channels in it. I don't know what to do. It is only receiving non cable channels. Help me so I don't have to keep watching...
alot of universal remotes dont let you program your tv with them due to how much more mem they would need. you have to use your actual tv remote or do it manually with the tv. sorry
Jul 29, 2007 | Sharp 13VT-R100 13 in. TV/VCR Combo
RCA F36650 36" TV Logo
256 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
