Washer displays dl when started - Washing Machines
Dl f flashing
Posted on Jan 04, 2009
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Receive a DL error when trying to start my front load washer (the door will not lock)
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
A dl is flashing on the display when I start it
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 03, 2010 | Maytag Bravos MTW6600T Top Load Washer
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont turn on. code is F dL. any thoughts?
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Washer displays dl when it attempts to lock the top and start the cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Dl error- washer won't turn over to start the cycle
dl error refers to " Lock Error ".
  • Door Lock Mechanism broken or removed from the Door
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Fails
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
