HP Photosmart C5100 All-in-One series does not scan to my computer
  • vtudo509 Nov 22, 2008
    doesn't scan to computer why not?
. Click on "Start," and "Windows photo gallery."
2. Under "Windows photo gallery" click on "File" and " Import from camera and scanner."
3. Select the "Lexmark X1240 printer" and click on the import button.
4. To begin the scanning process, click "Scan Now.
Posted on Jan 19, 2009
In need to know if my C5150 will work with a Windows 10 laptop?
Which C5150 do you mean?
If you have an HP Photosmart C5150 all-in-one, it will work with Windows 10. HP has the full-featured (drivers and the HP Photosmart Suite) and diagnostic software here: https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-c5100-all-in-one-printer-series/1153538/model/1153544 .
If you have an OkiData C5150, the available drivers for that support Windows 7 (32 or 64 bit) and older versions of Windows. The compatibility tricks that let older drivers work may not work with Windows 10. (Microsoft now requires signed drivers and the available x64 driver from Oki may not meet the requirements.)
I hope this helps.
Aug 14, 2017 | Computers & Internet
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C6280 will not scan documents to my computer. I have it connected to USB port on my wireless PC. I try scanning thru solution center and that does not work. I have turned off the computer,...
Solution
For Windows XP
*Go to Control Panel > Printers > HP Photosmart c6200 series > Right Click > select Delete
*Load the CD / Downloaded Software for HP c6200 series
*Select add a device > select usb (if preferred)/ wireless
*Wait for the installation to finished and repair the settings.
*Restart PC/ Try Scanning Again.
If it doesnt work, I suggest try uninstalling and reinstalling the software completely using the CD itself.
Hope this works. Good LUCK!
Feb 14, 2010 | HP Photosmart C6280 Printer
I have a HP Photosmart C5180 printer and am trying to install it on my PC. I have the disc that says HP Photosmart C5100 series for Windows 2000, XP I get so far into the install and it tells me my print...
please perform the steps below and then try to install the software:
1. Click Start , select Settings , and then click Control Panel .
2. Double-click Administrative Tools .
3. Double-click Services .
4. Right-click Print Spooler and select Stop to stop the services.
5. Click Restart to restart the service.
6. Click OK .
7. Restart the computer.
Oct 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have lost my ink level viewer. Hp Photosmart c5100 series. It used to show everytime I printed but now it is not there and I can't seem to recall it.
Did you install non-authentic HP cartridges? It doesn't like that and witholds information as punishment.
Try putting the following address into your web browser:
http://192.168.1.6/
this brings up my ink levels. However, I don't understand these things and you may need your own individual printer specific code.
May 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a HP 2575 photosmart 2575 All in one series
Are able to print? If yes, please tryy to scan by using Ms Paint. If you can scan from Ms Paint please reinstall the scanning driver software. You can download the full feature drivers and softwares from www.hp.com.
Mar 18, 2009 | HP Photosmart 2575 All-In-One InkJet...
Can't get any of the 4 printers to print.
Go to "control panel" select "printers and faxes". Right clicking on the printer that you are using will allow you to select it as 'default printer', 'delete printer', 'rename printer', etc. If the printer you are using is there and is not check marked, select as default. Check to see if it now works. (you may have to restart computer) If it already is the default , delete printer. If you feel the software is ok and want to try to reinstall, you must first turn off the printer and remove the usb cable. The software will tell you when it is ok to plug your printer into the computer. If you do it to soon, Vista will try to assign its own driver. Which may be you original problem. Isn't vista fun?
Jun 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Wont scan to my Mac
I had the same problem and got solved by speaking to the helpful HP helpdesk - all that I needed to do was delete my installed HP software and redownload it from the internet and now it's working
Feb 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
1,005 people viewed this question
jasbo
jasbo
