Question about HP OfficeJet 7310 All-In-One InkJet Printer
All-in-one 7310 Scanning to 8.5 X 11
When I scan, it always scans to legal size - then I have to change it to 8.5 X 11. How can I set the default so it scans to 8.5 X 11 instead? I tried ticking a button marked "automatically crop", but then I apply and click OK and still the next time I scan it scans to legal size.
Thanks!
  • oar321 Aug 07, 2008
    neither of those things worked - still shows legal size.
I am scanning A4 size pages but the when I open the scanned PDF they open in legal size so it is smaller in size. Please help...
Hi Smitha
Look its due to settings only. Hence check to make sure the default paper size choosen by you is A4 and not legal. Because that ever the size you provide it scans to it. If still problem persist the try to email me the correct model number on the printer.
May 01, 2014 | HP Officejet Pro L7780 All-In-One InkJet...
HP Photosmart C309a default scanner paper size
Hi Norman,
Are you trying to scan from Printer to PC or Activating SCan option from PC ?
On your PC, Open Solution Center
Click on Settings option below
You will find Scan document options - select it
you will find the Size of paper set, Change it to Letter
Regards,
Sean
Jan 31, 2013 | HP Photosmart Premium C309A All-In-One...
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
I am using Omnipage 17 through Microsoft Word 2003 wth an HP scanner. I am scanning text. The default page setting is for legal size paper, and there is a long list of paper sizes one has to scroll through...
Linda I suspect you can open a template called normal.dot and change the paper size then save the template.
see
http://www.geekstogo.com/forum/topic/131676-change-office-word-default-paper-size/ - the second answer given ..
Dec 09, 2017 | Nuance Communications Omnipage 17 Pro
Scanner keeps scanning 81/2 x 11 paper and saving as 81/2 x 14
The scanner driver is probably set to save as 8.5" x 14" as the default. Open the Lexmark scanner utility or driver properties and look for the default scan settings. (These will include file type, resolution, and scanned image dimensions, among other settings.)
If you see that the current default setting is 8.5" x 14" (or "legal") you can change it to 8.5" x 11" (or Letter), or if there is an option for automatically detecting size based on the original's size, you can do that as well. Click OK or Apply to save your changes.
May 20, 2010 | Lexmark P4350 All-In-One InkJet Printer
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at:
Facebook.com/BestCreditRepairManualor at
BestCreditRepairManual.com 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
162 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
