Home | Sony | KDS-50A2000 50 in. HDTV Television | Sony KDS-50A2000 scr...
Sony KDS-50A2000 50 in. HDTV Television
Problem for Sony KDS-50A2000 50 in. HDTV Television
Sony KDS-50A2000 screen is in green tint
By carr4268 on Jul 31, 2008
My sreen color is green and I have reset the tv
Same Problem
May 11, 2009
-   Ive had this issue with my 50A for a few months now. I have yet to find an adjustment within the menus to remove the discoloration. -   jeremycrouse
Feb 02, 2009
-   I have the same problem. Calling Sony for resolution...
stealth_trooper@hotmail.com-   GOVNAH
Dec 03, 2008
-   I wonder if dust on the main mirror may the issue? Possibly filtering out the other components? Just tossing that out.-   Guest
Oct 22, 2008
-   I have the KDS-60A2000 with similar problem. The screen size is the main difference, from what I have learned. Thank you, REX TV store for selling me an extended warranty. I am aware of a Class Action Suit against Sony for other models with this problem. I wait for the Authorized Technician to come and let me know the news...I had my last big screen for 12 years and this was my "updated" model. I will let you know how things go. -   HighTekMom
Sep 01, 2008
-   I have the same problem, a green tint to the screen. I have tried ajusting the color with no results, sceen is still green.-   jkries1
Best Solution
posted on Sep 22, 2008
Very Helpful)
swigstavern
Rank: Apprentice
Rating: 100%, 2 votes
My Sony KDS 50 A2000 is 17 months old. Its the 50 Inch SXRD projection model. About two weeks ago the screen developed a green tint with cannot be tuned out, then a few days later the message began to appear on the screen that the bulb was nearing the end of its life and must be replaced.
Fortunately I have the Circuit City extended warranty.
I called and within just a few days a serviceman came out and replaced the projection bulb.
The Result: No change in the picture, the green tint remains on all channels, so I'm awating the next service call. Under the service warranty they have the option to repair or replace this set. If indeed this is the light engine (optical block) which I suspect and its going to cost $1,000 or more I may be looking at a new set.
When it works this is a great TV, but I have had three Sonys now including two other standard CRT models and now this one joins them in the junk heap, the other two also bit the dust after just about two years. Is it time to give up on Sony?
I know they have a class action suit on a similar model for this same problem. Caveat emptor
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 22, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
They just looked at mine 10 minutes ago it is the OB (optical block) I got a quote of $1000 to fix it I'm calling Sony right now, my TV is less than 2 Years old
Popular Solutions for Sony KDS-50A2000 50 in. HDTV
Questions and Unsolved Problems for Sony KDS-50A2000 50 in. HDTV
Do you recommend Sony KDS-50A2000 50 in. HDTV Television?
Answer
Answer
picture is on the green side and I tried to adjust it in the menu but no help
Answer
I tried a new lamp. That did nothing. I tried all kind of different settings and that did nothing.... (More)
Answer
I just put in a new lamp,but didn't seem to help.
Answer
i have the sony kds 50a2000. it keeps on overheating and shutting down. the fan that expells heat... (More)
Answer
i have the sony kds 50a2000. it keeps on over heating and shuts off. but the fan by the light that... (More)
7 Other Users Have The Same Problem - Continued
Comment by Buub, posted on Aug 30, 2008
I have the some problem even with the changing of the lamp at 208 dollars which was recommended by the TV .It started at the corners and has sincecovered the whole screen .
Comment by Guest, posted on Aug 09, 2008
Got the green tint too. I tried all the settings and easy stuff. Looking everywhere for help.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KDS-50A2000 50 in. HDTV...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
