Question about Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A/37 problem...light on front flashes 7 times.
I am removing the back cover now to see what the error message is. The same thing has happened to me...which looks like has happened to several others...It started being difficult to turn on..then I'd have to unplug and repulug it in to get it to come one...now nothing happens except for a click in the back and the flashing light in the front...Once I see the message on the back panel...what to do next?
Thanks,
Jennifer
  • skarom939 Oct 24, 2008
    Looks like Philips is ****! Already invested 400+ in fixing it, worked for a month and now the same again! I am not spending a penny more on this set.
  • Axle80
    Axle80 Jan 13, 2009
    Hey sparks, I could use that info, thanks!
    Scholar:
  • 52 Answers
There was a problem with the software for these sets, you can go to philips website and download it and install via usb..
But if the tv isnt powering on at all and you have a flashing error light on the front. Then either the powersupply, y sus or z sus board is bad or possibly even the control board. If you havent resolved this issue, respond back and I can tell you how to test them.
Posted on Aug 12, 2008
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Tv turns off and I get a red flashing light on philips flat tv model 42PF7320A/37
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Sep 30, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Red light flashes & times
7 blink error is 8.6 volt error usually tied to y main board. would advise to disconnect y main from power supply and verify vs voltage. if vs is present replace y main and general protocol is to replace y upper and lower buffers as well as they complete circuit
Aug 10, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
42PF7320A/37
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397).
REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal.
HISTORY:
23-03-'06: Chassis added. Text updated.
Jun 13, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
