Washing machine overflows and doesn't run through cycle - fault 39
Have a IW810AU F&P top loading machine.
When using, the machine over fills and then stops and readout says
"Fault 39".
I have spoke with a technician and he suggested a pressure sensor problem.
I made sure the clear tube from the bottom of bowl to control panel wasn't blocked. What else can I do and am I looking at the right problem?
    Genius:
  • 1,028 Answers
Does washer keep filling with power removed if so bad fill valve if not be sure clear hose has no holes in it last possibility control bd pressure sensor is part of it be sure clear hose is clear all the from top to bottom and not pinched any where
Posted on Jul 31, 2008
Agitator doesn't run
The problem could be transmission failure
May 23, 2013 | GE WWSE5240D Top Load Washer
Iw810au
That model would need more than just a fuse,
A lot of other parts in the board are blown as well,
Have a technician look at the board,
Before you buy a new/recondition board.
May 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
