Question about Toshiba 50H71 50" Rear Projection Television
Toshiba 50H 71
Hi
i also have a convergence problem with the red not moving to line up.
u mentioned in am earlier post to buy STK392-110 and the link worked great but how many do i need to purchase? do i need 1 for each color or just one for the red.
thanks so much for your help!
Will this work for a tz55v61? my red will not move left or right just up and down
Posted on Oct 25, 2008
  • Toshiba Master
  • 8,617 Answers
Its recomended to replace both at the same time as each IC controls one color and half the green so when one goes out the gree tends to weaken the other. You can get them with free instructions at the following link.
http://servicemanuals.vstore.ca/
Posted on Jul 31, 2008
My tv toshiba 40h80 the red and yellow line up but the blue doint it moves up down but i caint get them to line up with the reds and yellow.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | Toshiba 40H80 40" Rear Projection...
The red will not line up when it is in the
You have a yoke and screen voltage issue with your red crt tube. If the red moves but not enough to do the convergence then you may be able to adjust the red crt. If the red doesn't move at all when you try to do the convergence then you most likely have bad convergence IC chips that need to be replaced. They aren't expensive, the last pair I did cost $36, but it involves taking the set apart and doing some tedious soldering. If you have no experience with this sort of repair you may want to go to a shop, They will charge $300-$400 to replace the IC chips. If you want to try this yourself post back and I can help point you in the right direction.
Nov 29, 2009 | Toshiba 50H81 50" Rear Projection...
Convergence problem
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 30, 2009 | Toshiba 43A61 43" Rear Projection...
Red bowed lines
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Aug 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
My toshiba 42h81
Your convergence amplifiers have failed. There are lots of posts on this site for this problem. Take a look at this link:
http://www.fixya.com/support/t261950-43h71
There are a couple of links on this post that you will find helpful if you want to repair this yourself.
If you have more questions just ask.
Dec 28, 2007 | Toshiba 42H81 42" Rear Projection...
TZ-55V61 Convergence
Do you still need assistance?? The convergence IC's are always
on the largest heatsinks in set......have you replaced??....T.
Aug 22, 2006 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
