Question about Canon FAX-JX200
Not sure how to setup the tel/fax mode correctly
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Aug 03, 2008
  • Cheryl Whalen Aug 04, 2008
    Marybriffa:
    Given that these are the exact, detailed, step-by-step instructions for how to accomplish exactly what you said you were "not sure how to set up ... correctly", may I ask if there is something missing? If not, is there some reason that you would choose to rate this response as Helpful (fair) as opposed to Excellent (FixYa)? I also indicated that if, for some reason, you felt that you needed more help to rate at FixYa that I would be glad to provide that help, Please advise if you need further assistance. Thank you for using FixYa.
    smartsolve
How do i change from manual receive mode to auto?
You want "Fax/Tel" Mode. To do this follow instructions below.
To set a receive mode follow the instructions below.
a Press Menu.
b Press a or b to choose Initial Setup.
Press OK.
c Press a or b to choose Receive Mode.
Press OK.
d Press a or b to choose Fax Only, Fax/Tel, External TAD or Manual.
Press OK.
e Press Stop/Exit.
The LCD will display the current receive mode.
Apr 04, 2011 | Brother MFC-465CN InkJet Printer
Why does my fax machine ring and ring but does not pick up when someone is faxing me
You dont give make or model ...however most likely reason is that your machine is set to something other than "FAX" mode. ie:- it could be in Tel mode, or Tel/Fax mode. Have a look at the display screen.. depending on make and model it may say something like TEL..or FAX in the display.
Check your operators manual for the correct way to set your machine up.
Jan 11, 2011 | Office Equipment & Supplies
The fax keeps ringing it does not pick up
This sounds like the FAX mode is not set properly.
Follow these steps.
Press Menu
Press up or down arrow until it displays "Initial Setup"
Select Initial Setup
Press up or down arrow until you see "Receive Mode"
Select Receive Mode
Select your choice: Fax Only, FAX/ Tel depending on your connection.
If your fax is connected to a telephone line that shares dial tone with a handset, choose FAX/Tel
Press STOP/Exit
Jun 15, 2010 | Brother MFC-6890CDW Printer
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
Unable to receive fax without picking up hand set - any pointers? We have the setting to Auto
CHECK THE CABLE IS IN THE CORRECT SOCKET AT THE BACK THE CABLE NEEDS TO BE PUT IN THE LINE SOCKET NOT THE TEL SOCKET AND ALSO MAKE SURE THE RX OR RECEIVE MODE IS SET TO FAX MODE IF IT IS JUST A FAX LINE OR TEL FAX MODE FOR USE WITH PHONE.. THE TROUBLE IS USUALY WHEN YOU ARE USING THE FAX ON A LINE USED FOR TEL USE AS WELL..__
Aug 05, 2009 | HP 1040 Plain Paper Inkjet Fax
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Canon faxphone will not recieve fax
Most of my fax mahines I setup,I setup with the fax only mode,and then I change my incomming ring to 7.This give you enough time to answer the phone and minnimize the risk of losing faxes.If a external phone is connected to the phone and you receive a fax call,you press 25 on the external phone and the fax switch to rceive.
Feb 27, 2009 | Canon FAXPHONE L80 Laser
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Brother IntelliFAX 5750e Laser
Is tel line going into correct socket of fax? (Line not Ext.)
Is Fax set to auto answer or manual?
If you pick up line or press speaker button can you hear other fax sending if so press start and hang up you should receive fax, and you have just proven that machine is in manual receive mode!
I think you will find it  will wake from sleep automaticly if setup correctly.
Oct 11, 2007 | Brother IntelliFAX 5750e Laser Fax
Canon FAX-JX200 Logo
184 people viewed this question
old marine
old marine
Corne Viljoen
