Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
I'm installing a wpn824 Netgear router and at the end of the installation process it appears the window to login into their site with user name: admin and when I tried my own username and password it doesn't work.
What is the proper step to be done?
  • 173 Answers
First try to register your product and then try to login with that user name nad password
Posted on Jul 31, 2008
Connecting netgear rnagemax router to clearwire
Restart the modem and router and you should be connected.
Feb 05, 2018 | NetGear RangeMax WPN824 Router
How to install netgear router WPN824 V.3
check out
Sep 04, 2010 | NetGear RangeMax WPN824 Router
How do i re-install netgear wpn824v3 w/o the cd ,i used the restore button
On any PC connected to the WPN824, open a web browser, any URL. The device automatically redirects to the configuration wizard after factory reset.
The manual can be found here: - you may want to start at page 2-8 for a guide through the configuration process.
Feb 06, 2010 | NetGear RangeMax WPN824 Router
Need specific instructions on how to install w/o
from router with ethernet to computer.....then open up your web browser and type in the address bar, a pop down login appears user/login= admin, and password- password. click okay. now you should be looking at the netgear config page. there is a button or tab you can click on that says wireless settings, so click it......first is the SSID which probably says wireless or netgear in it.....put in a name you will recognize when searching for your wireless connection......this is the Name of your wireless connection.... then scroll down to wep 64 bit encryption and select it. next, scroll down to key1 and type in a ten digit code (area code and phone number usually works great). leave the passphrase box above key 1 blank. once you have your code typed in scroll down to the bottom where it says apply and click the apply button. now , you need to double check that the netgear saved your new settings, so once the apply click refreshes the page scroll down and make sure its still there,,,,if not write down what the netgear replaced it with. once doublecheck is complete no need to apply again , just close your browser. then remove the ethernet cable, go down by the clock and right click your wireless network icon to view availbel wireless networks,,,, you then should be able to find Your SSID name and click it to then type the encryption in and now your surfing.
Dec 28, 2009 | NetGear RangeMax WPN824 Router
I am starting to install Netgear RangeMax Wireless Router WPN824 v2 I reset to factory settings. I have windows XP professional. The unit is powered, and connected to the internet. what is the next step?...
Once you have your router connected to your Modem, connect your computer to any open port on the router, and with your Web Browser, go to and log in to the router. Login is (default) login name is admin and default password is just a blank field. Once you have logged in to your router, go through setting up things like IP address (leave at "Get Dynamically from ISP". Same with DNS server --- "Get automatically from ISP". MAC address should be already filled in. Click Apply. You should be good to go for wired router use, and if you want to use it wirelessly then you need to click "Wireless Settings", pick your SSID (Name of your network) and any security you choose. After this you ought to be set for wireless access as well.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
How to do a complete reset of netgear wpn824 v2 have pressed reset button and nothing have used holding reset button with unit on for 20 sec then off 20 sec then on again for 20 sec with out releasing...
Well it seems that you have uploaded the firmware on the router using wireless connection. The firmware on the router has corrupted and now does not seem to be recoverable.
Dude if it is under warranty then get it replaced. To log a complaint with NETGEAR go to this site:
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 05, 2009 | NetGear DG834G Router
Router login?
The details should be username:
those are the defaults that read in the manual of rangemax wpn824
Let me know if you need anything else.
Feb 17, 2009 | NetGear RangeMax WPN824 Router
Cannot register my new product, netgear router WPN824
go to
click login/register
Sep 22, 2008 | NetGear RangeMax WPN824 Wireless Kit
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
213 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
