I get a 02fa fan error. It says to shut system down and check fan. Fan is spinning and im not sure what the problem can be computer just goes diag screen and thats it i can get into bios.
  • chizeks Apr 11, 2009
    Same Problem here with Gateway Computer
BUENAS NOCHES LA SOLUCION ES CONFIGURAR EL BIOS DE LA LAPTOP .
ENTRE F2 ADVANCED LUEGO DISABLE EXECUTE - DISABLE BIT CAPABILITY TAMBIEN DISABLE QUIET BOOT MODE Y WAKE ON LID SWITH DISABLE GUARDE LOS CAMBIOS Y LISTO
Posted on Feb 11, 2009
My systen switches off by it self while am intensively using the numeric key
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 16, 2012 | HP ProBook Computers & Internet
Every time there is a problem of overheating error and my system shuts down .when i restart my computer cpu produce beeps . motherboard is of Intel 915 series is used.......
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is the problemis not fixed then the CPU will eventually fail.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Sep 09, 2011 | Intel D915GLVG Motherboard
Heats up quickly and fan is very loud
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 20, 2011 | ASUS CPU Heatsink & Fan, Cooling Fan
Hi, I ahe a dell computer model number dccy, i want to know why it turn off by itself, when it get to hot, when i have more than ten minute working with it, why if turn off
Aug 16, 2011 | Antec Computers & Internet
My system is shutting down and restarting and it shows system shutdown by thermal
Hi:
When you have a thermal shut down, the first thing to check is the Heatsink/fan assembly. When you computer is cool, open the side panel, and power up the computer, and make sure the fan is spinning on the processor. If it is, observe the interior of the computer, and see if there is alot of dust and lint build up around the fan assembly. Obtain some heatsink compound, and carefully remove the clip or bracket that holds down the heatsink fan assembly. carefully clean off the bottom of the heatsink, and the top of the processor, and reapply heatsink compound in a thin layer to each surface, and reattach the heatsink/fan assembly, after you have cleaned it up. this should take care of your problem.!
Sep 21, 2010 | Intel D945GCCR Motherboard
Hot cpu and restart computer
well if the CPU gets hot it will shut down...
no ifs nor buts nor maybe it will shut down, reason being the cooling system and the fan is meant to keep the processors cool and if they over heat then the system cannot perform or stay up, it may be the fan so check into that if not run an hardware diagnostic on your system...
to do the hardware diagnostic go to;
CMD the type the chkdsk in the box and hit enter..
you can also do CHKDSK /f to fix errors or CHKDSK /r to repair errors... but those would not be with overheating and shutting down but regular chkdsk should get you an asnwer if anything is wrong hardware related...
Aug 07, 2010 | Dell OptiPlex GX520 PC Desktop
I have a desktop PC, Gateway 5472. I am running Windows Vista, and a variety of productivity suites. It has a 500 GB hard drive, and 4 MB of RAM. My computer has an unusual problem...one which has...
Hi, Well looks to me a problem with either your Fan (or cooling system) or RAM (memory). If your machine shuts down itself (without restarting) most probably the Processor cooling procedure has failed. Without a warning the System will shut down immediately to avoid any damage to the Processor.
  • Have you experienced a 100% CPU usage? You can check it using your Task Manager.
  • Have you checked your System Temperature? If your System has a built-in Temperature monitor use it. Or you can check it using the BIOS. It has a location which displays System Parameters. Monitor the temperature. That has to be the problem.
  • Check your fan. If it has been damaged it will not be able to function as expected.
  • Make sure your power supply is able to provide enough power to the CPU Fan and other devices.
  • Make sure you fan has no loose connections.
  • Make sure that its clean.
  • If you have problems visible with your fan, please replace it.
  • Make sure that your Processor has no loose connections. Its must be installed to the slot or socket properly. The heat sink must be installed properly.
  • Make sure your power supply has no internal leakage or extensive heat.
  • If your machine Restarts without shutting down:
  • Most probably an Issue with your RAM or Hard Disk (or an Operating System Problem has been detected).
  • If it launches Windows Repair Process it might be a problem with one of these devices and / or the OS as well rather than CPU.
  • You can use the Event Viewer to check for System Related errors. What you have to do is type Run in the search box in the Start Menu, hit enter then.
  • In the Run box, Eventvwr.msc and hit enter.
  • Go to System category and check for Errors. (Red X mark represents errors).
  • Read the description and try to check whether an error is logged. If so please post it here for further assistance.
  • You may need some hardware knowledge to perform these tasks (except the Event Viewer and BIOS check). If you do not have any experience please take the machine to a tech.
Feel free to contact again. Comment here.
Please be kind enough to rate the answer as well!
Thanks for using Fixya! Have a good day!
Jul 13, 2010 | Microsoft Windows Vista Home Premium with...
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
Protect mode
I own a Sharp DVD Micro System XL=DV60 that began to have a "protect" error message when I crank up the volume. Not sure if this applies to your system, but it could be worth a try. Before you proceed, the solution requires you to open up your system (Do not proceed if the unit is still under warranty :)).
IF you are not experienced in opening up electronic equipment, I suggest you find somebody who does. The error on my system was caused by the cooling fan being stuck or not able to spin. The system has a sensor or sense circuitry wherein, when it detects that the "amplifier" IC heats up, it spins up the fan to cool it down. IF the system detects that the fan is not spinning during the cooling phase, it will give out the "protect" message. Note that the fan only spins when you crank up the volume. Less or 0 volume will shut down the fan due to it's "energy star" feature. One possible reason why using headphones does not show the error, since headphones require less energy that the main speakers, thus the amplifier IC does not overheat. To solve the problem, I cleaned out the dust in the system via a 1 inch wide paint brush (haven't tried the compressed bottled air used to clean computers BUT it might do) and nudged the fan. Played the system w/o a cover and observed the fan operation and so far it has solved the issue. I plan to lubricate the fan shaft with very small amount(less than a drop) of machine oil using a syringe. If it does not work, I plan to see if I could purchase a replacement motor for the fan...
Again, I have not seen the internal layout of CD-BA2100 and not sure if there is a cooling fan. But then again, it's better than having the "protect" error popping up. :) hope this helps....
Oct 27, 2008 | Sharp CD-BA2100 CD Shelf System
Computers & Internet Logo
1,167 people viewed this question
David Payne
David Payne
