Question about RCA D61W20 61" Rear Projection Television
Tv makes a loud "screaming" noise.
Started out only after a while. Could unplug for a few hours then it would take a while to come back. Now is instant as soon as the picture comes on. Seems to fluctuate with the picture. Sometimes pulses and screen seems to shrink on both sides.
  • Anonymous May 15, 2009
    I have the same problem but just noticed the noise is only on High-Def channels. other non high-def channels are ok.
    Genius:
  • 1,030 Answers
From what you descirbe this is an idication of a faulty flyback. the flyback is a special high voltage transformer that generates high voltage for the picture tubes. when you replace this you ussally replace horizontal output transistor. THis repair usally run 125 to 300 at our shop.
Posted on Jul 31, 2008
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Van wont start, loud, has a burning smell and the oil light is on
I'd feel best if you can find a reputable mec and have it looked at. There are a mess of things that can make loud noise. You could have anything from a bad berring to a blown engine. When your'e on the road remember go to someone who is reccomended or a national chain or dealer..
Apr 24, 2010 | 1996 Plymouth Grand Voyager
Kitchen Aid refrigerator is making a very loud noise!
when you transported this unit did you lay it down or stand it up? If it was layed down then you should of waited at least 24 hours before plugging it up again to give the oil in the compressor time to settle back down. Actually either way it was transported it still needed the 24 hour rest time. So if you automatically plugged it in after transportation you could have messed up the compressor. Let it set unplugged for 2 days then plug it in and see what happens. If loud noise persists then you know the compressor is shot. Goog Luck.
Sep 02, 2009 | KitchenAid Refrigerators
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Samsung HLN5065W, SVC#HLN5056WX/XAA - Made 12/2003
check the color wheel in front of the lamp
May 25, 2008 | LG 42LC7D-UB Television
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
