Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No power Does your posted solution for NO POWER - power button blink 1 then 3 also apply to the post 1 blink then 9 blinks? Plz see my post 6/23 with same problem, I have 1 blink then 9 blinks . My unit RCA Model D52W20, S/N D202C10C5, Chassis# ATC221,Service #D52W20YX1,Bar Code #CA396D202C10C5, Thomson Inc., May2003 Thank yopu very much for your time and help.
  • ohbaby0243 Aug 03, 2008
    Our 2003 HDTV - model # D52W20YXI, was working at night when we went to bed, the next morning it was flashing the 5 blinks, then 9 blinks and it continously repeats the sequence and it won't turn on. Can you help us?
    Signed confused...
  • RCA Master
  • 8,617 Answers
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Posted on Jul 31, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Plustron lcd TV/DVD NEED CODE
Try this solution posted by Ipsita: http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
thank you to IPsita if this work:
The contain below:
icon_minipost.gifRegion code hack posted by ipsita, January 11 2008:
1) Remove the dvd (if present) from the player
2) Open the tray
3) Press STOP on the remote
4) Press 7 0 on the remote
5) Press MENU on the remote
6) You can see the current region on the top of the screen
7) Press the appropriate region code, e.g. press 5 if the region code needs to be Russia. Press 0 to make the dvd player region free.
8) Press MENU
melnavz
Aug 23, 2008 | Televison & Video
Hi I have a TH50PZ80U that is flashing two red lights when I plug it in. If i press the power button for 5 seconeds it will flash 10 times. When applying power the AC relays click, after pressing the...
Hi bschaub796,
10 times blinking of your unit indicated that the processor sense the missing 15v from the power supply. This problem is quite technical since I've already read your post that you have a reading of 15v in P25.
Now, we have to examined it deeply to determine where the fault came from between the two board.
If you have a 15v coming from the power supply but its go to 0v after a while which trigger the 10 blinks, you have to check the feedback circuitry of the power supply for faults. If you can't find any faulty parts on that section means that the feedback circuitry trigger to shutdown because it sense fault in the D board.
Remember that it has a good regulation output from the power supply, the issue here is the feedback circuitry that sense the fault. If you are going to ask my opinion I've suspected that the fault is in the D board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 17, 2011 | Televison & Video
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
The power light comes on for 5 seconds then goes out and it does this 3 times then completely powers down. when i hold in the power button it blinks 1 time then a few seconds later it blinks 9 times what...
It sounds like youre talking about a RCA ITC222 chassis HDTV if so you need a flyback and CP150. Post the model number and I will post a link where you can get the parts with free instructions oh how to do the repair.
May 04, 2009 | Televison & Video
TV won't turn on. (Panasonic 1080i HDTV)
The power led blinking is an error code if you can reply to this same post and let me know the number of blinks I can assist you with what it means.
Jan 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Same problem
Press 1 after 9-9-1. The "1" code is the TV code.
Feb 23, 2008 | Jensen JR400 Remote Control
Power blinks green on lcd 17" veiwsonic
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
17" lcd veiw sonic power blinks
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
285 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
