Question about Refrigerators
Model Number LFX21960ST Ice maker not working. Temperature set at zero degree F. Lever arm seems like it is frozen.
  • franktg78 Nov 09, 2008
    same unit and same problem any ideas
HVACRH20
  • 237 Answers
SOURCE: Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Posted on Dec 26, 2006
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
kdgrayson
  • 195 Answers
SOURCE: MY MODEL 3211RFD sub zero ice maker quit. Got
timer
Posted on Aug 23, 2009
How can I free up the ejector arm on an ice maker?
Worst case, Remove all frozen items. Turn off freezer or increase temperature to above 32f apply heat with a hair dryer or similar device to the Ice maker particularly near the bottom surface. This should allow you to remove the auger and all ice frozen to the auger. Perhaps less extreme steps can be used to accomplish the auger removal. There may be Ice maker "install" instructions that may make my explanation a little clearer.
May 04, 2015 | Kenmore 26.7 cu. ft. French-Door...
Subzero 501F icemaker slow in making ice
More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
May 03, 2012 | Frigidaire Refrigerators
Not producing ice. I've already checked the lines at the wall and the line that comes in at the freezer. They are not blocked. However, still not producing ice.
Check the following:
- The freezer temperature, it needs to be below 10 degrees F to cycle.
- If the freezer is cold enough lift the bail arm (wire on the right side of the ice maker in the freezer) until it clicks and stays up. Close the freezer and wait 20 minutes. Come back and lower the bail arm, watch the ice maker and you should see it cycle, you will notice the white 'fingers' rotating very slowly. Make sure the room is quiet, after the cycle runs for a bit, (minute or so) watch for the 'fingers' to be straight up in the 12 o'clock position, you should hear a buzz coming from behind the refrigerator for about 7 seconds. If you hear this sound then the ice maker is working and the temperature is ok. If you do not hear the buzz the most likely suspect is that the coil on the water valve in the back is bad, you will need your model number to find the right part.
Apr 18, 2010 | Whirlpool Refrigerators
Ice maker isn't making the ice, but the water supply is working to make water? does not seem like the water is coming into the ice chamber it was frozen at the end of the spicet, so I took everything out...
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Kenmore 53542 / 53544 Side by Side...
Ice maker not making ice
Mar 31, 2010 | Sub-Zero 632 / S
I have a Kenmore side-by-side model number 106.53669300 with an automatic ice maker. The problem is the ice maker is not working. I have 120 volts at the receptacle, but only 34 volts at the harness for...
HI. These symptoms seem to point to a failed thermostat. During this type of failure, the ice maker will not be able to regulate the freezing of the ice. It may not be able to preform a complete cycle, as well. The successful jumping indicates that the module is functional, but the regulatory device is not. This can also be a starter switch issue, also. This will be the On/Off switch or arm lever. To isolate the issue, simply test the thermostat. Use the procedure below to achieve this.
The thermostat is located near the bottom of the support box. The thermostat is connected by two or three wires. Label the wire placement before disconnecting them. Remove the thermostat by loosening the clamp, by pushing back the retainer clips, or by removing the retaining screws.
You will need to test the thermostat for continuity using a multimeter set to the ohms setting X1. Start by testing the thermostat when it has come up to room temperature.(Usually after about 10 minutes after you have removed it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity. Chill the thermostat in the freezer
for about twenty minutes and retest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combination's 1 & 2, 1 & 3 and 2 & 3 and write down the results. Two of the combination's should yield a reading of infinity and one should yield a reading of zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combination's should now yield a zero reading.
If the thermostat fails this test, it should be replaced. If the thermostat passes the test, move on to the on/off switch arm and circuit inspection procedure.
Let's start by inspecting the arm. The arm extends away from the ice maker above the ice cube bin. During each ice making procedure, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops. The arm is supported at one or both ends. One end extends into the back of the front support. If it is not securely in place, it could cause the ice maker to malfunction. Make sure that the arm is securely in place. I would also advise to inspect the clearance of the arm. make sure that nothing is blocking the arms swing pattern. If this arm is in the on position, and dose not make ice, this can indicate that the entire module is suspect. This will require total replacement of the ice maker unit.
Next, will will move to the final inspection sector. This will be the actual on/off switch circuit. In order to test the on/off switch circuit, you will need to remove the entire ice maker unit. The shutoff switch is located near the shutoff arm. Remove the switch by removing the two screws that hold it in place. The switch is connected by three wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors. Firmly pull the connectors off of the switch terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Touch a probe to the side terminal. Touch the other probe to one of the two other terminals. The reading should be either infinity or zero. With the probes still in place, depress the switch. You should now get the opposite reading. Keep the first probe on the side terminal and move the other probe to the second terminal. The test results should be the opposite of the first terminal. If you had a reading of zero on the first terminal, when the switch was depressed, you should get a reading of infinity on this terminal. If the switch fails either test, it should be replaced.
Jan 11, 2010 | Refrigerators
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Maytag model number RSW2200E stopped making ice, water dispenser still works though
Hi: Maytags have issues with ice makers. But before you call service... Try setting your freezer colder. The ice maker is thermally protected so it will only make ice at 0 degrees F. Not just frozen, but 0 degrees. Ice cream should be rock hard. In the summertime this happens a lot. I just had to set my Amana colder, as the ice slowed in production. Give it 24 hrs to stabilize in temperature. Don't do the human nature thing and open it every hour to see if ice is made as you will just dump the cold air out. I hope this helps, Jeff.
Jun 21, 2009 | Refrigerators
Ice Maker Has Stopped Making Ice
Hi: I didn't see the simple first solution to try in your list. The ice maker is thermally protected. It won't make ice until the freezer is at 0degrees F. Set your freezer lower in temperature. It may seem cold to you but it has to be at 0degreesF. Frozen at 32 degrees wont cut it. Please don't open the door every 5 minutes to see if it's made ice, as it will raise the temperature. It appears in your question that you listen for the ice to drop. That's the right way. Give it a day to drop in temp. before resetting the temp. This is a free try before you have to call a technician. I hope this helps, Jeff
Jun 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Amana af12538aes Refigerator No lights, ice, water
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Jan 19, 2009 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
