Question about Microsoft Xbox 360 Console
Prolem with xbox
Saying im not connected to xbox live saying wireless is not working but it is
We have 2 xbox 360 live 1 ps3 live 2 laptops and 1 computor.having probs with 1 xbox,keeps saying test connections.my netgear wireless-g cable router sais speed 1x coverage 1x do i need a stronger wireless router to cover all these above,if i do could u recommend a wireless router please thankyou
Posted on Apr 16, 2009
    Problem Solver:
  • 5 Answers
Well if it IS working, you wouldn't be here would you? XD
anyways go to the wireless settings and manually add your SSID and WEP/WPA if applicable. If this doesn't work, get back to me.
Posted on Jul 31, 2008
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Cant connect to xbox live from xbox
If your other computers on the network are capable of surfing on the net then you might be blocked out from The Xbox live Microsoft :[]
I'm not sure but maybe you could try using a USB to Ethernet or wireless network card instead of the internal card ?! It might help if they are blocking ppl by controlling their MAC address!
Good Luck!
Bruce
Dec 07, 2009 | Microsoft Xbox 360 Console
How do i find my WEP key, I have a Belkin 54g router
hi im an xbox live support representative
you could actually just call your router manufacturer so they can provide your'e wep key
if you still have some issues just call xbox customer support
thank you
Jan 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect to live...wireless.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox live wireless network failure
did you go into your computer settings? i think you have to take your firewall off maybe. im not totally sure on this one. good luck though! if you call microsoft they might have better answers sorry!
Dec 27, 2008 | Microsoft Xbox 360 Console
Wireless network always fails for xbox live.. i need help
go to settings and conection settings and put your connection setings in
Dec 26, 2008 | Microsoft Xbox 360 Console
WRT54G xbox live DNS fail
log in to your router and forward ports in the router, call 1-800-linksys they'll assit u to fix your issue,
Feb 27, 2008 | Linksys Wireless-G WRT54G Router
Connecting to xbox live
I can make it work for you
Feb 11, 2008 | Microsoft Xbox 360 Console
Connection error
Call xbox customer support 1-800-4MY-XBOX
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
96 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
