To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure. NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt. CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed. CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
SOURCE: upper and lower ball joints
Your better off have it done bt a tech because you need a press to press them out and in. Also you will have a warranty witk the work. You want to be safe messing with your steering and suspension. I hope this helps.
SOURCE: Lower Ball Joint
You will have to remove it and replace it with a new one. The general steps for doing that is: 1)remove the tire 2)remove the caliper and rotor 3)remove the outer tie rod from the spindle 4)remove the axle nut 5) remove the cv axle 5)remove the nut on the ball joint 6) bang ball joint out and press in a new one. Then reassembly is exactly the reverse as disassembly.
SOURCE: Replacing Ball Joints on 2001 Mazda B2500 (upper and lower)
its easier to get the whole control arm and the lower one has to be pressed in. it is not and easy job if you dont have the right tools checkout rockauto.com to look at the replacement parts and to get a price on them
SOURCE: Need new lower control arm ball joint repair
If you go to (www.repairpal.com) and enter all your vehicle info, and select the repair in the list, it will give you prices for your particular area, based on your zip code.
Testimonial: "Thank You!"
