Question about Gateway GT5220 PC Desktop
Desktop locked up-o
My desktop program is locked up it's moving very slow I have windows xp pro which it did not come with the system
Compaq presario s5100nx very slow windows xp
1GB of RAM is not enough to run Windows XP and the programs you installed efficiently. Removing unnecessary programs should make more memory available for necessary programs but it will never be fast. is a great resource for memory upgrades but I don't think you should invest in a computer that old with a completely unsecure and unsupported operating system (XP).
I hope this helps.
Feb 06, 2014 | Compaq Presario 5000 PC Desktop
My internet is running slower.
Yes. Symantec security slows down the system a great deal.
Jul 20, 2010 | HP DC7100 Intel Desktop PC - Intel Pentium...
Having freeze up and very slow loading of
i suggest you 3 different ways to handle this.
1.if tou have a windows cd. just insert it and select windows repair and proceed to the instructions.
2.purchase any any good registry repair and computer optimisation software suchas IOLO SYSTEM MECHANIC ,REGISTRY MECHANIC, ADVANCED SYSTEM CARE etc.
3. to be cheap and effective, you may use trial version of IOLO SYSTEM MECHANIC.
these will optimise your pc automatically.
Mar 02, 2010 | Dell OptiPlex GX280 PC Desktop
Old program won't run on new computer win XP but runs on others
> ran slow
Probably, having more RAM would make VMWARE run faster.
> except Sound Laundry 2.5
Check the manufacturer's web-site -- surely, they have a version which *DOES* work as a "native" application under Windows XP and Windows VIsta and Windows 7, i.e., no need for "compatibility settings".
Nov 05, 2009 | HP Pavilion A6400f Desktop PC, Refurbished
How do i install a new windowa xp profess. with out losing info and programs on old windows xp prog .New windowa xp pro is legit old one is not New = unopen windows xp pro. program that can be ''...
Just select the Upgradation option.. while installing the XP on your system.
by this Operating system will be upgraded without loosing any saved data.
Jun 13, 2009 | Computers & Internet
Uninstall XP Professional
If the computer was upgraded, then go into START | CONTROL PANEL | ADD/REMOVE Programs, see if uninstall Windows XP Pro is there. If it is you can uninstall it and not loose anything and the computer will reveert back to the operating system that was on there, before th upgrade.
Sometimes it is there, sometimes not.
If that doesn't work, then go to START | CONTROL PANEL | ADD/REMOVE Programs | windows components, and take out any uneeded components. Also check your system tray (bottom right by the clock) and see if there are eny programs there that you can close or better still uninstall as they eat memory and slow down your system.
Jan 08, 2009 | Microsoft Windows XP Professional for PC
If you are using Window XP then you can use PC DOC PRO which have bonus program WinSock Fix and NetAccelerator..
These programs are quite deliberately improve the performance of system.
Order Now:
Merry Christmas  Scott
Dec 25, 2008 | Microsoft Windows XP Professional
Problem w/ WIN2000 Pro & XP Pro
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
Gateway GT5220 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
