Question about S3 Trio64+ Graphic Card
ON-BOARD SETTING FOR SW1 ON S3 TRIO64V2/DX
ON SW 1 THERE ARE 10 ON/OFF SWITCHES. I NEED TO KNOW WHICH ONES GO ON OR OFF
    Novelist:
    Scholar:
  • 125 Answers
You need to let us know which motherboard you are using, and what CPU and memory on system!
Posted on Aug 04, 2008
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
Overall I have a switch at each end of the garage with two lights in the roof in between. Sw (A), Lite (B), Lite (C), Sw (D). SW A & D work as three way. I want to change out Sw D to a wall plug a
If this is what you've got:
"S3" are 3 way switches, black screws are the common or shunt. (Adjust colors of wires to what you have).
You can easily change it to look like this:
All S3s are out. Replace one with an S1 (single pole). The other S3 is now the outlet. Silver screw for neutral gold screw for hot. Outlet is always on, S1 controls both lights.
Please note: There are several ways to wire 2 three way switches (S3) to control a light or two. This is just one with a way to change this method to the way you're look for. Your wiring may not allow you to do this as easily.
May 08, 2014 | Electrical Supplies
97 toyota camry both fans continue to run
2 fans behind RAD
is 1MZ engine, the 5s is different. 1fan
1mz engine has 2 switches.
the twin fan engine is 1MZ (bingo)
the 1mz has 2 switches. a real pain when know one posts engine.
FSM data: ECT switches.
sw1--opens >208f closes < 190f
sw2.-opens >199f closes < 181f
i see the PCM has CF cooling fan control too.
my online source has 30+ pages of schematics
and covers it all but skips the fan wiring.
on the right fender fues box is the 4 or more fan /AC relays.
if you unplug the ECT sw1 or 2, or the relays im sure
you will find how is missing up and work from there.
it looks to me , (A/C drawings) that the PCM and A/C amp can both
control all fans but has 2 ways to do that.
PCM can see engine heat (ECT EFI) and activate fans when engine overheats, (normal at long idle times as stop sigs)
and the 2 , SW 1,'2 temperature switches are a backup i think too
all this and is staged, first 1 fan then next,
too bad the fan relay schematic is missing..
Feb 18, 2014 | 1997 Toyota Camry
1993 Saturn SW1 station wagon
No, the transmission can be removed without doing that. You will need to support the engine.
Mar 16, 2010 | 1993 Saturn SW1
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Video driver software
http://www.opendrivers.com/driver/2142/s3-trio64v2-dx-gx-graphics-driver-english-3.03.16-for-os-2-free-download.html
or
http://drivers.softpedia.com/get/GRAPHICS-BOARD/S3/S3-Graphics-Trio64V2-DX-GX-410012108.shtml
Jan 10, 2009 | Computers & Internet
1993 Saturn SW styles
SW1 is a single overhead cam. SW2 is a dual overhead cam both have multi port injection.
Dec 16, 2008 | 1993 Saturn SW1
Need the area on the motherboard
The SW1 Connector
This panel connector provides a set of switch and LED connectors found on
ATX case. Refer to the table below for information.
Device Pins
HD_LED_P 1
FP PWR/SLP 2, 4
HD_LED_N 3
RST_SW_N 5, 8
RST_SW_P 6, 7
KEY 9, 10
Pins 1-9 are closest to the edge of the board. Pins 2-10 are above 1-9. Number 10 is missing .
Dec 10, 2008 | EliteGroup K7SOM Motherboard
Ibm 61h2500 p/n 61h2471 sw1 and sw2 problem
All sw1 1-4 and sw2 1-8 = OFF, PIII at 133 MHz, SDRAM at 133MHz, and AGP card 2x, not 4x or 8x.
Try it PII and SDRAM 100MHz after.
Jul 22, 2008 | IBM PC 300PL Socket 370 Barebones Kit /...
Boolean Logic
I don't know the syntax but you could easily do this with setting the switches to a constant, then adding them up. The number set would need to be something so that there would only be one solution...the one that you were looking for.
sw1 = 1
sw2 = 2
sw3 = 4
If sw1 and sw2 is both on, but sw3 is off, the number would be 3
If sw2 and sw4 was on, the number would be 6
If all were on, the number would be 7, etc.
May 08, 2008 | Computers & Internet
Computers & Internet Logo
160 people viewed this question
Top S3 Computers & Internet Experts
David Payne
David Payne
Are you a S3 Computer and Internet Expert? Answer questions, earn points and help others
