Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips 60 Couldn't get the remote to work in an effort to adjust convergence. Got new remote. it works everything but the convergence. Red is off to the right about 1inch and blue is off to the left. Can't get either to move is there a manual adjustment? I see 3 images and it's driving me crazy. Thanks Jack
  • 1 more comment
  • sfriley Aug 02, 2008
    Me too!
  • 1Murda Aug 16, 2008
    moved tv and the convegence isn't lined up. tried to use the remote but the convergence wouldn't move at all.
  • Anonymous Aug 17, 2008
    i have a phillips hi-def projection screen, 50 inch. i have the same convergence problem that came about out of the blue. i have pink and lime green waving across the screen and cant get all the little crosses to line up. got no help when i tried to contact phillips. they are only interested in selling the new models. i dont want a new model and cant afford one. i like the tv i have now and just want it to work correctly again.
Sfriley are you seeing tripple?
Posted on Aug 16, 2008
I own a 60PP9401 60 in. Rear projection tv. My red convergance was way out of line. I placed tv in the shop a while back,cost me $300 to get it fixed! Got set home, red still out of line,but not as bad. My...
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
Jan 10, 2011 | Philips 60PP9401 60" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence
If the convergence can't be adjusted with the remote are if a tech comes out and he can't adjust it from the back of the set or the SAM replace the SSM part number 313503710091 that's where the convergence adjustments are done.
Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 9P6040C 60 in. Rear projection
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 23, 2008 | Philips 9P6040C 60" Rear Projection...
Phillips Magnavox 9P6031 C101...
Find a universal remote with a menu and four arrow keys, b/c Philips is out of the original. Or, you could call Philips and find the number for one of their authorized centers - a TV repair man may have a stockpile of them from cust's who abandon their TVs.
Feb 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
